Redcap
Redcap
Filters: 100
I am trying to be well balanced, and have been creating patterns... which I hate and have no eye for. What makes a good pattern, what do you want to have in the filter forge library? Do you like wallpapers or glass, or pavers, or whatever... Let me know so my patterns are junk smile:)
ronviers
lighter/generalist
I'm not even sure what a pattern is. smile:?: Here is a filter I worked on recently that I thought *may* be a pattern but I don't know. What do you think is it a pattern? I guess it’s the blind leading the blind here but I have been thinking about patterns too.
Here is the tentative description:
This filter allows an image to be modified using eight glass tiles. There are two modes; a select mode and an apply mode. The select mode is used to quickly select a pattern and the amount of curviness. The filter is then placed in the apply mode for so the tiles can be rendered. There are fifteen patterns to choose from and each pattern can be configured for more or less curviness.
Glass Columns.ffxml
@ronviers
Redcap
Redcap
Filters: 100
Like those wallpaper-esque filters, stained glass filters, ect.
ronviers
lighter/generalist
Thanks Redcap. After doing some looking around I don't think what I have would be considered a pattern. It appears that a defining characteristic of a pattern it that it *not* use the external image. I think what I have, even though it is a pattern generator, would fall into the category of distortions. It seems to always go back to that; external image, no external image.
@ronviers
----You can always put a switch, and make it both, B-l33t. smile:D
there is a patterns category in the texture section and in the effects section. no reason a pattern cant have an image component.
ronviers
lighter/generalist
Hmmm, that mucks things up a bit. So what is Glass Columns, a pattern or distortion?
@ronviers
It's repetitive so it's a pattern to me smile:)
ronviers
lighter/generalist
It seems that FF uses the category I submit to as a revers indicator of where they are placed. I don't think I have been right yet.
@ronviers
well, i'd call it a pattern.
15 unregistered users.
