Rawn (RawArt)
Texture Artist
Filters: 105
Maybe you filter twisters can help me out of this mind block.
I am trying to punch a hole in a wall (pictorially, not literally....unless i cant figure this out)...as you can see, I get a nice hole selection in my bricks, unfortunatly the mortar also ends up being cut out. I have tried quite a few things, but of no real success.
Does anyone have an idea they can share with me? I am probably forgetting something very basic....but for now I am stuck in my mind block.
Rawn
You might have to make the mortar seperate from that pict..Use the blend to put them on different layers.. smile:)
You can even post the filter it might help a little more...
Rawn (RawArt)
Texture Artist
Filters: 105
Good idea, here is the basic components of the filter.
I have one row that has a nicely masked black hole, and another that has a nicely masked wall. The only problem is there is no way (that I have found) to blend the masks and not have the mortar show up.
Rawn
brickhole-test.ffxml
Hope you don't mind CFandM couldn't help but have a fiddle, this is one way of doing it smile:)
Rawn (RawArt)
Texture Artist
Filters: 105
Hmmm...that just may work!
(or a variation there of)...thats a TON!
I really hit a mind block on that one smile:)
Rawn
Rawn (RawArt)
Texture Artist
Filters: 105
seems to be working great smile:)
I think it might be uploaded soon
Thanx for the help! smile:D
(still one more thing I wanna try with it first...though it might give me a headache LOL)
Rawn (RawArt)
Texture Artist
Filters: 105
wow...it wasnt a big headache afterall...i think the added shadows help alot!
Yep looked like that did the trick.. smile:)
Thats quite alright Carl, we were going for the same thing anyway..A solution for the problem... smile:)
ahimsa
Filters: 41
That looks very good. smile:)
Looking good Rawn the shadow and brick texture work well the real challenge would be to give the bricks around the hole depth [ faces ], the shadow works for giving that illusion smile:) as a substitute so to speak.
Cool Mr CFandM smile8) smile:)
Rawn (RawArt)
Texture Artist
Filters: 105
Yeah...adding real depth to the bricks wasnt working but between the shadows and the highlighting of the edges of the brick, i think it provides a bit of the illusion.
Its not perfect realism, but could be an interesting frame for pictures anyway. smile:)
Rawn
Carl wrote:
Cool Mr CFandM Cool Smile
Ah just call me C or F or M or CF or CFandM or Big scarey head..But Mr smile:?: smile:?: smile:D
Big Scary Head LOL using Mr and your first name is a colloquial term of affection/humor here, as in Mr Carl, but I'll take you up on CF smile:D smile:D
Redcap
Redcap
Filters: 100
I have an idea of how you can make a hole in the wall not have those random floating bricks....
Use frame to get a black circle, distor and stretch that circle and than put it as the noise of the brick, so instead of the brown standard color have the circle be the color of the bricks. Changes the bricks to solid fill, and you will have a rough circle blown out of the wall with no floating bricks. You can then color the remaining white bricks however you want to.
P.S. I am glad that my nickname has stuck for the big scary floating head... smile:D
Rawn (RawArt)
Texture Artist
Filters: 105
If I understand your idea, that is pretty well what I actually did do smile:)
Though the random brick holes actually give it a little character i think
Rawn
Hey, Mr. Helper (Carl) smile:) I have some filters for you to work on smile;) smile:D LOL....
Hey, Mr. Helper (Carl) I have some filters for you to work on LOL....
I feel bad enough about ecky thumping CF as it is LOL
