Stand alone always. (I assume this provides slightly better performance)
stand alone, unless i need to mask something first.
Rawn (RawArt)
Texture Artist
Filters: 105
I installed it as a plugin....though maybe standalone may have been a better idea. But I am in photoshop all th time anyway, so its no big difference smile:)
uberzev wrote:
Stand alone always.
+1
uberzev wrote: Stand alone always.
+1
+2 smile:loveff:
+3 Does run better outside of Photoshop.....
ssamm
Filters: 21
I mostly use FF in PSP -- where I'm usually doing "photo" type stuff and use the effects in layers. Plus I like to compare variations quickly, by just clicking the "eye" on the layers.
Zephos
Xyni says "Maximum w00tness!"
Filters: 31
I almost always use it in standalone mode when creating a filter. There are rare exceptions where I take it to Photoshop though for testing with unusual image elements though ^_^
-Zephos
ronviers
lighter/generalist
Exit PS? I don’t think so.
@ronviers
James
James
Filters: 46
Standalone most of the time
Whitedove
Miss Congeniality
I use it mostly with Photoshop, but I have used it alone.
Donna
Mostly stand alone for filter design but when creating art through PS..... Carl smile:)
MysticBlueRaven
Texture Artist/ Cavy Slave
Filters: 75
I mostly use it as a stand lone when I am creating filters and use it paint shop pro when I create art
Ad Majorem Dei Gloriam
I usually use it stand alone so it has more available ram.
you don't use PS as the OS shell???
RAM doesn't matter much, unless you use large images, say 3000x3000 and larger. Plus, Filter Forge is very good at managing memory, so you can render huge images even on a small amount of RAM. I wouldn't worry about this.
ronviers
lighter/generalist
PS as the OS shell
XP as a PS plug-in? I like it. smile:D Better yet XP and PS as a FF components. The first think I would do is plug the XP component in a threshold to clear away some of the clutter. Next I would plug the repeat curve into PS so I could have multiple concurrent instances. smile;)
@ronviers
Torley
Second Lifer
I use mine as a Photoshop plugin just about all the time because I haven't made a filter (I must be one of the few in these forums who's never crafted one yet), and because I mix it up with other tools when layering and makin' magic.
I didn't know there'd be performance gains when running as standalone — what kind of a boost can I expect to see?
I'm enjoying using Filter Forge to create http://torley.com/textures
jitspoe
Filters: 27
Primarily standalone here.
MeKenzie
Freelancer
Filters: 3
99.9% of my usage is in stand alone. Once, I used it with photoshop when I needed to crop an image before using my filter. smile:)
~*~Dm7~*~
17 unregistered users.
