ronviers
Hi,
Still working on my first filterjavascript:emoticon(' Big grin Notice on the control component labeled saturation in the first image is set to zero. In the second image it is set to 33% and in the third image it is set to 100%. http://picasaweb.google.com/ronviers/...7700777618 http://picasaweb.google.com/ronviers/...7895090850 http://picasaweb.google.com/ronviers/...3794436786 Now notice the corresponding change in the curve ops blend component. See how it pivots around the center and moves up and down at the right and left edges? This is so close to what I want to happen. I want it to pivot just as it does around the center but instead of moving up and down on the right and left edges I want it to move along the top and bottom. Do you see what I mean? Does anyone know how I can do that? Thanks, Ron @ronviers |
| Posted: April 18, 2007 1:24 pm | ||
| ssamm |
On a linear curve, move the Start to 50 and End to 50... -- it pivots similarly up to that point, but since the bottom of the line is always blue (unless I'm thinking wrong here), the curve can't pivot beyond that point horizontally like it did with your vertical pivot.
| Posted: April 18, 2007 2:32 pm | ||
ronviers
Figured it out! Thanks for the tip ssamm
@ronviers |
| Posted: April 18, 2007 4:50 pm | ||
11 unregistered users.
