ssamm
Filters: 21
I was thinking it would be cool to have a snippet filter that made a triangle, square, pentagon, etc… -- where you could select the size of the polygon and it’s number of sides. (And it would hopefully also be fast.)
I started to experiment around and got a possible idea, but I don’t think I will be able to finish this anytime soon (if ever) because of other priorities. So I’ll post what I did so far in case anyone's curious (and maybe inspires someone to do their own finished version).
What I did was make a decagon using a lot of parameters (with curves). My next step was to try to see if I could remap all those parameters using just one controller slider for the size (it seems like it could be possible -- the odd N-gons might be a little more tricky though...). Then my next step was to create the same thing for other N-gons, and put them all into a switch.
Anyway, here's my beginning test... (BTW, the three presets are just random sizes without very precise parameters yet.)
Maybe it’s amusing, if nothing else. smile:)
polygon2d.ffxml
Nice job.
The fundamental problem with your method though is it can't produce odd numbered polygons.
There is a another more versitle method that's based on the circular angle gradient. Maybe I'll get around to doing it what of these days. smile;)
ssamm
Filters: 21
With the odd N-gons I was thinking I'd end up using two curve-to-shape tasks/branches rather than just one getting mirrored...
But it sounds like you have a better method -- I'd love to see it if you do ever get around to it. smile:)
I don't know how you were going to acomplish this but since I was using your snippet anyway I thought I would take a stab at this..
Maybe a starting point..
Star Attempt 1.ffxml
ssamm
Filters: 21
Cool, CFandM.
I saw no point to the circular angle gradient until that filter. Very interesting, I'll have to look at both the filter and snippet more...
Excellent! The Three Snippeteers are back! smile:beer:
*rubs hands*
ronviers
lighter/generalist
Wow! smile:banana: Look at you guys go!
The masters of the curve. I have learned so much just by looking at these two filters.
@ronviers
hehe, just wait till you open one of their more complex filters, ronviers smile:D these guys eat polygons for breakfast smile;)
Oh yea, there are many uses for this snippet...Its also fun to play with.
Excellent! The Three Snippeteers are back! Beer
Glad its helping you to learn ronviers.. smile:)
Another reason I like posting filters...and there progress..
Yep give the playing cards a look.... smile:eek:
ronviers
lighter/generalist
I would say that when I looked at ‘Playing Cards’ my jaw dropped but my mouth has been stuck open for days from the sheer awesomeness of FF. My mind can only be blown so much – the full impact of playing cards will take some time to soak in.
BTW, I have tried for more than a day to create a radial gradient. It never occurred to me to try frame. It that how it’s done? Is that the only way? There is something about doing it with frame that bugs me but I’m not sure what it is.
@ronviers
Try this one from uberzev
http://www.filterforge.com/filters/671.html
This is where the one I am using comes from. There probably be other ways to do this
but at the moment there is none that is posted. smile:)
Been here almost a year and I still get blown away.. smile:D
CFandM, I think ronviers is trying to make something like this...
radial gradient.ffxml
Oops, yep sorry got confused there for a sec..That looks good Uberzev..
ronviers
lighter/generalist
Thanks for showing me how it's done. I really wish I would have figured it out for myself - that's what I get for asking. Some day I may come up with something. smile:loveff:
@ronviers
Sphinx had me thinking about this again...This is just a very small update to the curves...Then named the controls...Have fun with this....
Star Attempt 2.ffxml
Cool! Starting to get that SuperFormula look smile:)
I wondered about the discontinuities/seams in the outline (you see small offsets here and there)and took a look at it - it seems the angular gradient construction is wrong, I tried using a bias instead of that gamma, it looks better now, but its really just a guess. I should take a closer look at it sometime.
I also fixed the alias issues with the base gradient, and added a feather control.
Star Attempt 2 - Sphinx.ffxml
