ronviers
lighter/generalist
Hi,
I just found FF yesterday and it appears to me to be one of the coolest programs ever written. I am working on my first filter (ever) and, as is about to become clear, I have no idea what I’m doing. I know what I want to do though.
I have selected Perlin noise as a starting point. I then connect that to threshold source input. This combination gives me the shape I want but the transition from black to white needs work. I would like this transition to be gradual where it is dark gray and abrupt where it is lighter gray. Also in this transitional area I want to be able to control how much lateral crinkle it has.
I am not asking for someone to tell me how to do it because I want to figure it out for myself but I am not having much success just plugging things in at random so if would give me a hint on how to proceed it would be very much appreciated.
Thanks,
Ron
@ronviers
Hey ronviers I'm sure you will get a hang of it, I suggest you download some filters that you like and open them up, checkout how there constructed - also the snippet filters might be useful........... good luck and I'll look out for your first filter............ Carl smile:)
Something like this?
Abrupt-Gradual.ffxml
ronviers
lighter/generalist
Hi Carl,
Good advice, I found one by Richard Bartlett called Wartorn that is a close approximation of what I am trying to do – although not exactly. I opened it in the editor and so far have found it a little confusing.javascript:emoticon('smile:?:')
Question Thanks for the tip, I will study it and hopefully make some sense out of it.
Hi Vladimir,
Not quite – but only because I did a terrible job of describing what I am trying to do. That said, I learned a lot from your example and hopefully my next question will be better.
Thanks,
Ron
BTW, Richard Bartlett; member in good standing of the of FF user forum and author of Burninator – is the man.
@ronviers
Presidio
Presidio
Filters: 43
Hi there Ronviers,
I'm brand new to Filter Forge too however I've been making graphics and "using" filters since 1998. If you havn't used filters exstensively in the past you might want to play around in your paint program a bit- to get a feel for the basic ones. ((It helps to know how a filter operates when you are using it)).
For Example: If you've ever used the filter Super Blade Pro then the "curves" in the component area will look familar for beveling... And then of course all the basic image filters. Just to helps to know what they do before trying to build with them.
Stuff like that. A good starting point for making the filters is just to start at the result box. Relax and play around instead of tyring to do a certain thing, for now. That way you don't tie up your creative powers when making a filter smile:)
About FF- you know I never got involved with Filter Factory but I can convert a mean .ffl to an .8bf. LOL
Well glad I'm not the only newbie here smile:) Nice to meet cha. Hey and when you make you're first filter I'd love to see. It was so exicting to finally make these things after wanting to make them for sooo many years.
Persidio
ronviers and persidio, welcome to FF smile:)
the key to all of this here in FF is knowing the individual components and what they do and secondly, how things interact. there are a lot of help files now with FF, including a growing wiki help section. i'd suggest taking one item and working with that for a while till you can predict how that one item when plugged into another is going to look. when you can predict the outcome, you've got it nailed. when you plug a perlin noise into a threshold using the standard default settings of each, it's going to look a certain way (before moving any sliders). if you can predict that outcome, move on to the next thing.
i've been at this a while and i still get fooled by certain outcomes. stop right there and examine why it looks like it does and you'll get the hang of it. read the helps. learn the individual tools. that's the key. it's great fun to just 'plug and play' and come up with something interesting, but when you get to the point where you actually want to produce a distinct, particular effect, you HAVE to know the tools... or do a LOT of hunt and peck smile:) hunt and peck can be fun, but is also time consuming.
steviej's work is actually a pretty good example of how to learn filter forge. steveij, since coming here, has been working almost exclusively with curves. he's produced a lot of filters in a short time and most all of them are fairly simple and most all of them dealing with the curves components.
it also helps to post here. wiki's are fine. help files are fine. tutorials are fine. but, sometimes you just need to get some feedback. this is a pretty good group of folks here. the devs are extraordinarily helpful and accessible and so are the forum members. so, post away. we've not bitten too many heads off here smile:)
ronviers
lighter/generalist
Hi Persidio,
Thanks for the welcome. I have not used filters that much, usually because they do not do what I want them to, but I have used PS ‘Styles’ extensively and there are a lot of similarities there too. I had a new idea for a filter and it’s simple enough that I think I can pull it off. I am working on it now.
Hi Kraellin,
Thanks for the advice and valuable information. I am not able to predict many results yet but I agree that that is the key. I will take a look at steviej's filters asap. It is a good thing you guys do not bite off heads - I am hypersensitive and my spirit will be crushed. After one day in the Adobe Illustrator newsgroup and I never went back.
Thanks,
Ron
@ronviers
Presidio
Presidio
Filters: 43
Thanks for the welcome Kraellin,
You are exactly right. The advice I gave was for someone who doesn't understand filters. Help files are great but for newbies experience and clicking around is learning in itself; then they are ready for help files.
Now I'm an old graphics gal so I am ready for Filter Forge help files. In my years making graphics I've always painted heavily with filters and that's what I was trying to say- because it helps significantly to have a knowledge of how the filters interact, absolutely. I started out on Adobe PhotoShop, then Paint Shop Pro and finally Ulead Photo Impact when it was "Version 4"... this version is now up to 12- ... version 4 was 9 years ago. I think Adobe was Version 5 or so at the time- I can't remember. So I think I know filters, LOL. (((I'm a filter addict))). Just never got to make them before. smile:D
If you look under my user name you can see the ones I've made in 3 days. I've got something like 27 days left on my trial. One of my filters has 11 downloads already and the rest have no takers. Oh well I like 'em. (I know the downloads do not make a filter popular- it's filter use after the time period it comes out of the average stage- of which they don't say how long that is- but downloads are good smile;) )
And oh... LOL... mine are not playing around, I do know exactly what I'm doing. Maybe not with Forge Forge, LOL. But with graphics.
I made a filter (just now) that sounds like what he wanted. (Graphics I can do) but... how do I attach a .ffxml of it to the post??? I can't find it in the help file- I'll look again. ((Looked again and no info on this)). But if you could tell me that would be oh sooooo great~ smile:)
The one I just made was sent for upload so it won't be on-line for a bit. It's called "Moon Cheese". Figured he could look at the filter layout and get some ideas for what he wanted to do since I think this could be what he is thinking about.
Thanks again for the warm welcome,
Persidio
P.S. Ronviers- I made a filter set like the one you want to make- if I can't figure out how to post it here in this thread then you can search for it tomorrow. It's called "Moon Cheese". Then click on "Edit Filter" and you can see the components used. Hope you like.
Presidio
Presidio
Filters: 43
Okay I figured it out- simple posting stuff... I was thinking the forum and the program were a bit more connected then they are smile:)
Ronviers this is one of the filters I made earlier today- Now I used a violet purple instead of white like you're thinking about- but other then that I'm pretty sure this might be exactly what you are trying to do (minus the purple)??? See the other variations when the filter loads. I hope you like.
I uploaded it to the Gallery today (should show online soon).
Let us know how it goes.
Here's a big tip when it comes to graphics programs and filters- frustration is all part of the process. I'm not new to filters or graphics but I do remember what it felt like- hang in there. In fact I taught graphics making on the web for 4 of the 9 years I've been making graphics (I don't teach anymore- but anytime you need help- email me- I'll help ya). Being new to filters is not fun. It's gets better. And when you get done clicking around then check out the help files. Take you're time and click around first.
When I first started in '98 I had visions of taking a sledge hammer to my computer- instead I just melted out the motherboard. *grin* Best not to hurt you're PC when learning Adobe and Filters hey? LOL
Gotta run~
Moon Cheese.ffxml
ronviers
lighter/generalist
Hi Persidio,
Just got a chance to take a look at Moon Cheese, it’s very cool and nicely done but not exactly what I had in mind. I am attaching something a little closer but still not what I’m after. I did this, like I do almost everything, with styles not filters. With CS3 we will have smart filters so they will be easier to integrate into my workflow.
You certainly are prolific! Seven filters already – gosh. Keep up the good work and thanks for the valuable tips.
Brgds,
Ron
@ronviers
Presidio
Presidio
Filters: 43
((((( Nice!!! ))))) I love it. smile:D
Glad you liked Moon Cheese. smile:D
There's nothing wrong about staying with what you know. You'll know when you are ready to take the next step with filters.
When I read your first post it was very clear you were not ready for help yet. When someone says "don't tell me how to do it", they want to click around and figure it out. I've seen people who want help before and they say something very different. LOL. Normally something like "HELP,HELP ME!!!". Something like that. *grin* When you get to that point others are here and so are the help files.
7 filters... I don't think "Pattern Maker" and "Rose Bush" have hit the Gallery yet- but I've sent them out. Fun to make; also makes me feel good that others can use them. Submitting them to the Gallery makes me feel part of the community- verses if I just made them in the program saved for personal use only.
I've done my Filter Forge Filters in the stand alone program - so everything is straight Filter Forge. If I go to my graphics program to load the .8bf (adobe compatible plug in) then I'll get my head into graphics making and won't be making filters for a bit- ... I know myself. ~chuckle~
So??? Did you load you're filter in the gallery?
Persidio
Hi Ronviers & Presidio smile:)
I feel exactly the same way about it smile:)
Welcome to the neighborhood smile:)
ronviers
lighter/generalist
I posted it but it has not shown up yet. I have already found a bug with the selection selector so I will need to update it as soon as I get that figured out – no big deal. Plus I am working on way to add a slider for shadow detail. I decided to do a photo filter first just to get my feet wet and get comfortable with the components. Next I hope to do the terrain one I have been thinking about or maybe a lichen filter – I like moss and lichens for effect.
Do you have a website or online gallery?
Brgds,
Ron
@ronviers
Quote Persidio wrote: Fun to make; also makes me feel good that others can use them. Submitting them to the Gallery makes me feel part of the community- verses if I just made them in the program saved for personal use only
I feel exactly the same way about it Smile
Welcome to the neighborhood Smile
+3 on that one Stevie..
Welcome to all the fun... smile:D
Persidio and ronviers
+ 4 hi Persidio.......... Carl smile:)
ronviers,
it takes about 24 hours from the time you submit a filter to when it will be accepted and show up in the library for download. except, if you submit on friday or the weekend, it generally wont show up till monday.
Presidio
Presidio
Filters: 43
StevieJ, CFandM, Carl, (((Hi back at 'cha)))
Hey Ron, Oh lichen filter please! I'd go nuts for that filter for graphics projects~ I'm not into terrain much it all depends on the graphic/filter.
Web Site... ROFL I've had so many web sites over the years. I also know HTML and CSS (cascading style sheets)- I like to code by hand. I got into CSS when I ran a very large forum that made 'forum skins' for other forums. It was big. I needed to spend more time with family so I gave it away to a graphics friend. Before that couple of big graphics web sites and a very large graphics help forum. Was spending so much time helping others that I didn't have any time left to create graphics just because and not for a purpose. So I ripped most everything down (Graphics Supply and Graphic related sites) when I gave the forums away to friends. I've got some very old graphics friends I propably should go hang out with. ((But they'll put me to work making graphics)). smile8) And besides I don't want her to give the forum back!~ too much work~ Never again. Although I'll start the pages again some day- I'm not in the mood to spend the time on them at the moment. This year some time.
I did however just spend a shiny penny on some nice web space but I'm too busy with other things right now. Back when I was new to graphics (a long time ago) my first big site was ranked high in the search engines- hubby got jealous of all the time I was spending on it- so I tore it down. He felt so bad later because even after it was torn down it was ranking #1. LOL Oh well. Many web sites followed that one.
You got a web site out there Ron? Oh slider for a shadow... hadn't thought about that but... you know let me think about it.
Whooo HOOOO!!! Check you out~ Also; I luvs photo filters. So let me know when it's online or drop me the xml in a post smile:) I want the lichen too.
Hi Kraellin, I didn't know that about the Friday to Monday loading for the Gallery. Thanks smile:)
Well all I gotta watch my long posts smile:D So I better cut this short...
Persidio
ronviers
lighter/generalist
Ok Persidio, here it is. smile:D Let me know what you think. ssamm said it was "nice" and after looking at his/her work this is high praise. smile:ff:
I just bought a domain but I don't have any space yet. It's called interboundgraphics.com. I have a google web album but I mostly use it to post files to on a temporary basis. I have only been working in graphics for about a year, a year in July, and really haven't done anything worth looking at yet.
I feel bad for your hubby, I have made mistakes like that and you just can't take them back.
Brgds,
Ron
@ronviers
ronviers
lighter/generalist
smile:( Shoot I forgot to attach it - here it is.
Lab Enhance.ffxml
@ronviers
Presidio
Presidio
Filters: 43
Oh my Gosh!!!!!!!! This is so good!! And you have no idea how much I'll use it. I have some photos to enhance today for my Mom- and I'll let you know how they turned out. ((Photos are of my child and I don't put her photos on the net at all- not even forums)). Otherwise I'd show you. You know what- I have some photos of my yard last summer with flowers; I'll try the filter out of some of those pics and ... I can post that if you wanna see how they look in action. smile:D
When I went inside the filter and saw all the work you did my jaw dropped~ Ron that is one sweet filter!~
Oh Hubby- he's the best. I didn't mind taking them down for him- but it was when he changed his mind and ... then.. ARGH... all gone! ROFL
Nice domain name smile:) A year in a graphics program is a turning point- from that year on out it just gets better and better. Congrats!~
Gotta run be back later,
Persidio
ronviers
lighter/generalist
That’s the most encouragement I have received since my decision to get into graphics. I can’t wait to see if my filter works for you. I would love to see the pics. If there is something you want changed or added I will either update it or better yet make new one.
I agree, don’t even think about placing your children’s photos online.
I hope you’re right about the year being a turning point – it does *feel* that way.
Ron
@ronviers
Presidio
Presidio
Filters: 43
(((Hi))) Well I made a little something for you with your filters. smile:D
This is a daylilly from my yard last year- giving you the copyrights to the image as well as the entire display. It's a present for hitting your first year in graphics. If you can get thru that first year the rest is down hill. LOL Graphics are fun now.
The work you put into this filter is amazing. If you plan to make more photo filters I'll give you some more flower photos (just you though). smile:D
You did good smile:) Very professional~
Persidio
Presidio
Presidio
Filters: 43
Tried to send .psd then as .png so that you could change the display to your liking. Both were too large. Just email me if you want the .psd or .png and will try to send that way.
ronviers
lighter/generalist
Persidio Persidio! You are so nice. Of course I want the PSD. You can send it to [email protected] when you get some time. I still have to earn it by sticking with graphics until July but now I am reenergized – not that it was ever in doubt.
I tried to follow some of you filters but each step comes as a complete surprise. It seems anytime I look at other peoples filters they seem so clever and creative while my steps are so simple and obvious. I like, for example how you got the gradient to tilt in ‘Luxurious Silk’ by using noise. I tried and tried to tilt a gradient and never did figure it out.
Ron
@ronviers
Presidio
Presidio
Filters: 43
Hi Ron,
Please forgive for taking so long to get back; I'm easily distracted these days. Mom's been fighting breast cancer long story... my heads in the clouds.
Now see I don't think that's quite fair to yourself. I've looked at your filter which is complex, clean and intelligent. Sounds like you are finding your style and a certain style will emerge. So far it looks like you may be leaning towards technical artistic elements. Too soon to tell.
LOL but thanks for the creative compliments but I see mine my style as unconventional. As I'm always looking for a different path or blending not just in filters. Quite frustrating at times. *grin*
The trick is not to box yourself in. Sometimes the image will lead you and sometimes you will lead it.
Oh the curtain filter... Simple filter really when you look at it. Many times there is more then one way of doing a similar thing so instead of taking the main road consider the off beaten path- the curtain starts out rather basic then goes off road. Put it this way; if you have a CJ7 Jeep you wanna take it off the road right? Right. smile8) Push your creativity into unconventional mode and think of it as four wheel drive. You'll go offroad when you are ready and when you do you'll be taking that wonderful technical style of yours with you. I'm amazed at what you did with Lab Enhance. Very professional and technical.
The biggest tip I can give: Listen to your inner creative voice and take some risks. ((Sometimes it pays off and sometimes it doesn't, but when it does it's nice)).
Hope that helps. And I do plan on getting to my email tasks later tonight, LOL, haven't forgotten promise. Problem is I've got some filter play time today. Working on a gold metallic filter that has a mind of it's own.
Persidio
ronviers
lighter/generalist
I guess you’re right, in my previous pre-graphics life I was an access guy. This is someone that deals with highly technical equipment such as CSU/DSU’s, muxes, routers, switches, servers etc. and while there is a lot of latitude for creative solutions the fact is they are not encouraged. To avoid burdening the technicians that will follow, access people substitute creativity with an approach called best practices. It took years to get my brain furrowed into this state and I expect it to take years to get things back to normal. Fortunately I don’t have anything better to do and the good news is that I don’t come by the best practices approach naturally - I remember how things used to be.
I had to take a few days off forging too because I’m trying to make enough money to purchase PS CS3, but I am back until Wednesday - hopefully I will get one done. I have an idea for a new one but I don’t want to jinx it by talking about it. I am still hoping to earn a free FF but with only 1 filter and 8 downloads it has become obvious that I will need to design filters with a much higher coolness factor to them. So that’s what I’m working on now.
I’m not in any hurry- take as long as you want. I’m not going anywhere. Best wishes go to your Mom.
Ron
@ronviers
Presidio
Presidio
Filters: 43
Hi Ron,
I zipped up the PSD and some other images. Let me know if I need to resend.
Okay to clip the Persidio off the photos- you have permission to use- and if you have to have one without the watermark just let me know. Also if you need more let me know- not a burden I promise. Sorry about the time stamp on the horse photo- sometimes I like to time stamp photos then I forget to take it off other times.
Oh I had your style pegged right I see. smile:D
That's some job you have and easy to see you need a creative vent with the graphics.
CS3 is a shiny penny isn't it- OUCH. Nope don't talk about the filters if you think it'll jinx it. I'm changing my gold metallic some; a bright idea came while making it so we'll see what happens. I like it so far and that's key because I want to be able to use it in scrapbooking projects. Not sure if others will like it LOL.
Currently it's a ... metallic mask and changes depending on the image it's placed on. (((In testing phases and don't want to give out specifics yet))). Hopefully I won't destroy it by over playing with it. I did that on a beautiful back lit filter on my first day with FF and still have not been able to get that one back. The metallic one appears to be un-jinx-able but... even though I like it I'm not sure it's Gallery ready or that others would like it so I'll fiddle with it some more.
I was reading on the free FF's that there is a set average time limit on them so I'm not so sure if a free one can be earned in 30 days- however... I was told that you could request an extension to 90 days. I think the CS2 is the big hurdle at the moment.
TY for the best wishes for Mom... and thanks for understanding. smile:)
Can't wait to see the filter you can't talk about.
Nite
Persidio
