Hello, I have just discovered something that may be important to avoid problems when using the new awesome and amazing 3D noise phase available in the new FF14 beta.
Please, be aware that you must enable the phase checkbox BEFORE you begin to use the new noise component and connecting things to it, because IF you do it AFTER, all the connection done TO slots of the noise component will be lost and deleted if you do it later.
So then, if you are going to use the new 3D noises do not forget to activate and enable phase just after adding it so you do not loose your work of connecting other components to the noise component.
Rachel Duim wrote:
The Enable Phase checkbox is not in the editor view. Instead it is in the lower left pane when you select the component.
I wanted to help you let you know to avoid problems and surprise after using the new 3D noise components.
