I have just found the following images that are collages made with 50 or hundreds photos each one different
And in FF you can customize the way they are shown with separating edges if wanted
Or a small one
Or much bigger one with 15x14 = 210 photos
And this last example with a frame that could be made inside FF
For the above examples it seems that there are already some collage generators available
But the difference here to USE FF would be to be able to apply different random effects to each photo and maybe create a custom frame
Also a very good thing is that with FF you can shuffle, rearrange and jumble the images inside the grid and have multiple variations to choose from
But obviously the essential main problem to be able to do this is how to input 200 images WITHOUT HAVING TO DO IT manually on each individual color control component
POSSIBLE SOLUTION MAYBE THAT HAVE NOT TRIED IT YET
I searched on the forum and I found this old thread
Found a possible way to "batch" load multiple images in bomber plus
The solution is given much further down in the thread
So now I need to test it and see how it may work
18 unregistered users.
