| Novaesky | ||
| Posted: February 20, 2024 7:18 am | ||
The only way I know to do this: 2 bomber loops with a switch AFTER the bombers to pick one of the bombers, A lot of work... depending on how complex the bomber loop is.
For some bomber loops a scaling after the bomber would work. So if you had a loop with 7 repeats and a loop with 10 repeats scaling by 7/10 or 10/7 would give you the result you want. If you want an example let me know. UPDATE: here is an example of using the scaling trick in FF12. Repeat Scaling for Bomber.ffxml Math meets art meets psychedelia. |
| Posted: February 23, 2024 10:22 am | ||
