Zoltan Erdokovy
Filters: 24
Hey folks, I've been struggling with the following problem for a while so I figured I'd run this by the community smile:)
So, I have a black and white mask like this:
https://drive.google.com/file/d/1g3jUp...sp=sharing
I'd need to produce a fatter, cruder version of it, resembling a shape as if it was cut out of a magazine or something:
https://drive.google.com/file/d/1O0-eo...drive_link
Note the straight lines and that it entirely covers the original shape.
I'd appreciate any tips on how to achieve this. smile:)
Filters: 711
Here is a simple idea.
Fat Guy.ffxml
Zoltan Erdokovy
Filters: 24
Hehe thanks Ramlyn, this was my first attempt as well. smile:) I also tried driving a flat stones noise with the mask but still not quite what I'm after.
Here's an example using Stairs, Blur and Threshold. Lines are not all straight, but it looks like a paper cut in some ways. If this works for you I'll post it.
Zoltan Erdokovy
Filters: 24
Thanks but the polygonal look is very important, curvy contours don't fit the context it's going to be used in.
This is the best I could come up with using 8 Cells, union and intersection rules and scaling. Probably too jagged, but an interesting exercise. If it is possible to get this working better, I think using tangents to follow the edges would work better...
Zoltan Erdokovy
Filters: 24
Hehe exactly, I've tried many different ways and I too keep arriving at this sort of result: straight lines but a bunch of corners are sticking out. I have no idea how to snip them off.
Hm, I'll see what I can use tangents/derivatives for...
How about this?
Zoltan Erdokovy
Filters: 24
Nice. Techno noise driven by the mask?
Filters: 711
New version:
Fat Guy.ffxml
Filters: 711
Example 1
Filters: 711
Example 2
Filters: 711
Example 3:
Zoltan Erdokovy
Filters: 24
They are indeed on the right path.
I tested derivatives but I couldn't use them to produce anything better than what was already posted here.
I'll spend tonight on this but on Monday I'll have to start manually drawing the masks. :\
Here's mine, done with Bomber+ and post bomber Blur to remove jagged edges.
Magazine Cut Bomber+ alpha.ffxml
And an example:
Zoltan Erdokovy
Filters: 24
Thank you Rachel, I'll run this look by the higher ups. smile:)
