Now that FF 12 is already available and you can be able to save directly as a video file output (in FF 11 only makes the frames output)
I thought to show some animations that maybe could be an inspiration for creating filters to make animations and I can put here some possible examples
Here is the first one
New Order - Crystal - With shapes scrolling background Awesome music by the way
Viewing this video I think that it could be possible to make a filter that renders separate parts of the background and then after join them together in editing video software
It could be done with the circle dots overlay or not
Here is a cool animation
Sorry that it does not show here as I wanted to upload a 500kb mp4 video but it is not supported and compatible in the forum and seems that only GIF is allowed, but the same 500kb file in GIF format is 32 mega bytes so is not possible to upload, so I should use a video link
Here I have found some examples of possible animations
Textures or images could be cutout and mixed in animated way
It could be possible to make also animated reaction diffusion with the already available reaction diffusion filter available in library or in the forum
The below one is just a possible example but it could be possible to be done in many other different ways
Also to make cracks animations or other kind of fracturing or damaging
Also could be possible to use 3D cubes to make this
Artistic moving shapes
Spiral multicolor
pinterest link of the gif
Sorry that the animation is over 1 mb
Here are some cool geometric shapes animation that I think could be done with FF
Max Cooper Waves YouTube full video
The above one is very simple shapes and with very simple colors
But this other one is really much more complex Creative and artistic using different kind of Penrose tilings with many colors, Animated imagen and shapes that is worth looking at
Please be aware that at start is slow, is full power after the first minute
I would recommend that after seeing It at full speed, you see It at 0.25 speed to really be able able to see all the parts much better and carefully
Max Cooper Penrose Tilings video animation
And another example of the previos animation is this one below but there are a lot of different variations through all the above video
I have begun testing and experimenting with animating kaleidoscopic filter effects and I think that this may have a big potential.
(I will put another thread about what I have done when I discover and find out how to put GIFs on the forum using external hosting)
What I have done for now is very simple but I think that using FF animation with kaleidoscope could make wild things like this example shown this pinterest link
Here is a frame from this pinterest animation
Or this other more simple kaleidoscopic example using animated gradients that are available in FF
kaleidoscopic pinterest animation link
There is another kind of kaleidoscope animation example where it simple rotates 2 stripes spiral based fractal design in opposite ways to mix them together (in FF you can have the control to animate and move any shape how you want) as shown here
** Warning: there are some Flashing lights **
Youtube Psychedelic Mandelbrot Kaleidoscope Spiral Trails
Here is a screenshot preview
In FF you can make 3D shapes using gradients so I think that it may be possible in some way to also make some animation of multiple 3D gradient shapes like this one
Youtube Fractal forge VJ loop
Now for something different and is to animate geometric lines in a cool way and this can be done I think easily using Rachel filter shown on next post
Youtube Fractal Geometry Journey - Hyperbolic Flower of Life
From previous example I think that can be used the awesome and really well done Circular Reasoning By Rachel Duim that in some way is similar to the above although not the same.
But this filter may give an idea about it and I will test myself how this can be animated.
and for more simple animations using geometric circular lines here are 108 examples made in this whole video that is 1 hour and a half, but instead of spending this time, you can of course scroll through the timeline and see the ones available
Youtube 108 Sacred Geometry Animations, by Quentin Carpenter Natureofflowers
This one example below is available at 1 hour 08 minutes
I have found this animation where you have a fixed image but then some animated swirls appear and they will mix and thrash all the pixels around
zebra animation with destructive swirls on pinterest
I think that this effect can be done in FF animated
In this music video there are a lot of very short animations that surely can be possible done in FF as they very simple with rotating and moving things and shapes
Is a good point for inspiration, and It can be slowed down to 0.25 speed to see It better as the animations are very fast
Technotronic - Pump Up the Jam with digital art animations
Also the music is good too
In this screenshot the symbols behind are rotating sometimes randomly
Following from precios post in this the symbols are more and in a different way
Following the same as above there are also some animations with many simple geometric shapes moving in different ways
Here's Rotate Madness with animation added:
http://duim.com/animate/rotmadanimate-test03.webm
and Offset Madness with animation added:
http://duim.com/animate/offsetmadanimate-test02.webm
Right click to Loop
Oh! WoW this looks very good and great idea to use It in this way, like It
Also like the Offset Madness version
Will you make this available in the FF library if you can and want, and would be possible.
Thanks very much for taking the time to do this
Thanks SpaceRay. Yes, I will release these animations in the next couple of weeks. Here is Offset Twist Animated:
Right click to Loop. Safari support is limited with webm videos.
I halve found this animation on pinterest that looks really cool and lovely how all the colors are mixed and created with the motion but I have no idea how it can be done, so I thought that maybe it could be a way to be done in FF animated
pinterest colorful orb sphere animated
Found this on Pinterest and think that this can be done in FF in some way
Spiral multicolor
VERY SIMPLE KALEIDOSCOPIC ANIMATIONS
In Filter forge library there already maybe hundreds of filters that use kaleidoscope component to get this effect and being able to animate these may give some awesome and amazing results
Here is an animation I found on pinterest that I think is not made in FF but may be give you an idea of inspiration
kaleidoscopic animation
Here there is another more flower style kaleidoscope animation that is is cool and nice
flower kaleidoscope animation on Pinterest
Here is a screenshot taken
Is really curious that it seems that there are no animated filter that is based either on kaleidoscope animation like some of the above
or black and white animated stripes as shown in this YouTube short video
Fractal mandala Black and white stripes
Or this other similar to the above but not fractal in the same way this other YouTube short
Concentric black white stripes animation
Screenshot below to see what it looks like
And here is the third example of these black and white fractal stripes YouTube shorts
Fractal animated black white stripes
I will try something with this idea
Here a screenshot of it
And here is an example of a kaleidoscope animation as told about in 3 posts above in this YouTube shorts
kaleidoscope animated
Do not like at all the bad orange for my taste but is just an example
Screenshot preview
And for a kaleidoscope and black and white stripes example there is this animated YouTube shorts video
optical illusion black and white stripes kaleidoscope
Preview below
A better kaleidoscope example that looks like a digital flower that remembers me to the ones made by Rachel Duim (available on filter library )
psychedelic kaleidoscope
Preview of it
Here below is another preview of the same one above
So for today there are 6 new posts starting with the Fractal Mandala Black and white
Will see what I can do myself with these
By the way in the title should say that this is for FF 11 TO F14 Now available
I have done some testing with filters from Ramlyn to animate them and it works using the following
Triangle CircumNavigation By Ramlyn
Circular Flowers By Ramlyn
RadiCircular By Ramlyn
Gradient Mania By Ramlyn
Groovy Rays By Ramlyn
Multicolor Twister By Ramlyn
I have just found this Video example shown here In this link shown here with moving animated circles that looks like they have been made with bomber but I think is done in a video editing software
Is curious that This kind of animated kaleidoscope effect shown here in this 1 hour YouTube video and as shown on the below screenshot, so I am trying to do it myself and I will see how it works
The idea is that The source image instead of being still it can be moving and animated also, so it will generate different effects rather being still, and there could be a supply of multiple source images.
The problem is that I do not know yet how to make long lasting kaleidoscopes as in the video above, maybe the only thing is just to add a huge amount of FPS count? For example 27.000 fps
15 minutes × 60 seconds/minute = 900 seconds
900 seconds x 30fps = 27.000 fps
Don't forget that lengthy render time. smile:D Depending on the size of the video rendered...
16 unregistered users.
