JenniferK
Is there an efficient way to generate random (or, to get picky, superficially random) numbers to use in the math components?
Say I want to multiply a value with a random number between 1-5. How do I do that?
I've attached some code that only uses the Loop Randomizer. It's in FF11, let me know if you need an earlier version.
Also, there is a Map Script by ThreeDee in the forums that generates a random map of values between 0-1 which you can tweak for your projects.
Loop Randomizer.ffxml
23 unregistered users.
