parrotdolphin
I want to be able get the inverse value of an IntSlider number and then be able to plug that into a rotation input. Is there a way to do this? It seems like there should be but I just don't see how.
emme
You can enable the Use Remapping option in the IntSlider, and invert the output values in the remapper.
Alternatively you could use Invert, Tone Mapping, RGB math components etc.
There is no way, as far as I know, to output the actual integer HDR value directly, so you have to do the remapping manually based on the number of steps in the IntSlider.
Devs, maybe add an option to output the integer value directly smile;)
parrotdolphin
Thanks Emme! I am still not able to make it work correctly, but maybe I don't understand the way the math works with colors. I just want basic math. Here's a picture of what I want to do. The user should be able to change the iterations and have the rotation stay in sync automatically. If iterations is x, then rotation will get set to 1/x. I tried remapping but that doesn't work for what I want. I tried Divide (under RGB Math) and it does something but not what I want.
To do the 1/7 division you can use HDR values, which allow values outside of normal color range of 0 to 1. Using Remap on the IntSlider as follows: the range is 1 to 10 in my example, so the maximum map value is set to HDR value 10 by clicking the remap values to the left of the Divisor. Make sense?
Code of example in FF10
one_seventh hdr.ffxml
parrotdolphin
Thank you Rachel! That worked!
emme
It's also possible to make this work dynamically with a setup like this. Just set the stairs threshold to 0 and make the gradient length really large like 100000 smile:)
David Roberson
Artist
Filters: 37
I assume you would set that as x1, y1, x2, y2 = 0,0,1,0 (or 0,0,0,1)?
