JenniferK
Is there a way to change the default settings that components have? For example, Free Rectangle launching without the corners and bevels? Or Offset that starts at zero?
In the editor add the components that you want to change the default for. Change the values to what you want and then then right click on the component.
A sub-menu should pop up....Select Save Default Values.
So next time you add to the workspace that will be the new default for that component.
13 unregistered users.
