Helen Bradshaw
Hello,
Is it possible to create a custom frame in Filter Forge that can be exported and used with other images in Photoshop with the flexibility of changing colors of the frame in Photoshop?
If so, is there a tutorial or can someone help me out on how to get started?
Thank you!
I think that this is possible and easy to do if you are using Photoshop. ( there is a cheaper choice in the subscription for the Photographers plan for 10$ or 12€ per month or )
If I understand correctly, what you want is to create any custom frame made from any of the available filters that is made to include an image inside and then be able to export it to Photoshop and then be able to change the color of the frame to the one you may want
So if this is right, then you can choose any of the multiple frame filters choices already available as seen here when searching for frame in the FF library and use it in FF and then export the preset you may want to photoshop
Be aware that ANY of the the frame filters available that already contain a photo inside the frame can be easily removed if you choose an empty transparent option in the New image menu, and then export the frame with this transparent background
And then after change the color of the frame in Photoshop and here are some tutorials that may probably help you
METHOD 1 - FASTEST ONE
1-Minute Photoshop - Turn Any Color to ANY COLOR
Turn Any Color to ANY COLOR by Piximperfect in only 1 minute tutorial
METHOD 2 - MAYBE BETTER ONE
Turn White into Any Color in Photoshop (Even Black!) (just 9 minute with a great way explained and easy)
Turn White into Any Color in Photoshop also by Piximperfect
METHOD 3 - IF YOU WANT TO MODIFY THE OBJECT TO A SPECIFIC CHOOSEN COLOR
Trick To Apply a Specific Color To Any Object in Photoshop! (also just 9 minute with a great way explained and easy to do)
Trick To Apply a Specific Color To Any Object in Photoshop by Piximperfect
METHOD 4 - MODIFY ONLY SEL ECT COLOR FROM SOURCE TO ANOTHER ONE AND NOT THE WHOLE OBJECT
If you want to select just one or a group of colors fr om the source and modify all of them you can use the Replace Color tool in Photoshop
How to Use Photoshop’s Replace Color Tool by Planet Photoshop
How to Replace Color in Photoshop CC - Adjust Color Selectively by Piximperfect
Helen Bradshaw
Thank you very much! I will work on this.
