UPDATED SINCE FIRST POSTED
Here I have found a possible way to be able to have the rotation only at the 4 fixed full rotated version AND that does not use the Rotate component so it is still compatible with the FF Seamless option because the Rotate is a non-seamless component I needed to be able to use the rotation component equivalent (with seamless) but that the slider only has 4 points that it would give a fixed value that would give a full rotated version of the source content, I mean as follows 0, 0.25, 0.50 or 0.75 Using Value control 0, 25, 50, or 75 Using Slider 0, 90, 180 or 270 Using Angle Control So I searched in the forum and found this thread about rotation in degrees and found that CFandM have an awesome and clever solution in the 8th post that is Rotate Zoom 2 by CFandM but this includes a zoom option So I have modified it and removed the zoom part and leave only the rotation in fixed degrees part and fixed the wrong order of rotation Want to give a huge thanks to CFandM for making this possible Rotate in 4 degrees slider.ffxml |
| Posted: November 23, 2020 3:14 am | ||
27 unregistered users.
