chrisd
Hello All,
I am using the Image component and I would like to increase the resolution of an image within a filter.
The Scale component does not appear to do this, although I probably don't fully understand how to use it.
emme
Plugging the Image component into a Scale component and setting the scale to 2 will scale up the image by a factor of 2. This won't effect the canvas resolution. If you want to change the canvas resolution, select File - New Image (or in FF10: Image - Blank). You can then load in an image with the Color Control -component (check Allow Images and then Load Image under the Color menu). This way you can work with any resolution of your choice.
chrisd
Thanks, I'll give that a try.
chrisd
Emme, yes, Using the Color Control component does work for me
Thanks for your help
Its odd there is not a more direct way to do this.
Since I don't specifically care about the image quality, this will work.
If I did care about the results rather than just increasing the number of pixels, it might be good to have a specialized component to choose the sampling method, nearest neighbor, linear, cubic, bicubic etc.
I suppose it is assumed people will be using Photoshop or other app for this, so maybe its not critical.
Well... not that odd. This is both a plugin and a standalone app. So as a plugin a fixed pixel size is what you would expect. As a standalone program, it is a bit annoying, but it works with the color control so it could be worse smile;-) ...
In FF 10 there is a new component: Bitmap Cache. It provides filtering options, anti-aliasing options, downscaling, and caching. Close to what you were asking for.
