beto33
Posts: 38 |
| Posted: October 12, 2020 5:24 pm | ||
I think that maybe this could be done using a modified version of the great and well done Agamograph by Rachel Duim
| Posted: October 12, 2020 5:28 pm | ||
| Posted: October 12, 2020 5:46 pm | ||
| Posted: October 12, 2020 5:51 pm | ||
here is the fast test but still does not mix both parts in one
For it to work as showed above Preset 1 needs to have the Main Image trasparent so you need to go to go File --->New Image ---> and in Fill color make it transparent Preset 2 is the opossite, You must make the main image as the FF Ladybug, and the color control have the transparent color someone else needs to be able to mix both in one Agamograph 1 side only.ffxml |
| Posted: October 12, 2020 5:59 pm | ||
beto33
Posts: 38 |
It is almost there!! How about the pixelization of the image. And every filled square have a little perspective. But nice progress already!
| Posted: October 12, 2020 7:58 pm | ||
Sorry that I have tried to do it but did not get it, as I do not know yet how to mix both ones to make what you want
I think the pixelation may be easy to do and the filled square perspective I think that maybe is already given by the Agamograph filter although not sure |
| Posted: October 18, 2020 2:47 am | ||
This is a variation of the agamograph I did, in this example there are 2 "images", mona ane a grey value, and the effect starts in a different place (center instead of the edge). I will post a modification here in a day or 2 that looks more like the image on top. Also note that the image appears to have a cutout filter on it, which I may or may not include.
UPDATE: Too much work to change the current agamograph. I created a quick version by splicing 2 images together. ![]() Math meets art meets psychedelia. |
| Posted: October 18, 2020 2:26 pm | ||
beto33
Posts: 38 |
sounds great Rachel Duim.
| Posted: October 26, 2020 8:45 pm | ||
