Hello, I do not if this may be possible but I want that the IntSlider begins at a 3 value shown on the settings and not at 1 as it is now
Why?
Because I have connected it to the Polygon Sides node, and the first value available is 3 sides, and I want that the intSlider value is equal to the sides values, because now 1 = 3 sides, 2 = 4 sides, etc. and it would be much better to avoid confusion to make it that 3 = 3, 4 = 4 ... (As it happens with the slider control) so you really can choose the real amount of sides.
So please, is there some possible way that the Instslider in the setting panel to show 3 instead of 1 as the lowest value? Or instead that 1 = 1 and not 3
Thanks very much for any help
I do not know why the slider control starts at 0 and the equal value is 0, so there is no problem, but here in this int slider 1=3 and not 1=1. You can not use any other than a int Slider as it gives warning
I have seen the remapper, but this is different to others, and is only available there is only available
Step = 1 (you can not put any lower value)
Offset = 2 (you can not put any lower value)
If you increase Step to 2 then the minimum is 4, so 1=4
If you increase the Offset to 3 then the minimum is 4, so 1=4
I have seen already the intslider FF help page and have searched on the forum
thanks
