I have been able to make myself Inside FF the full and complete Sierpinski fractal triangle with 6 colors or images and will put it here later
It is finished just need some more work
The above one is the example I had found and here is the one I have replicated using FF without loops, just using Scale, Flip, Rotate and offset
I have made an exact copy of it
and now here is the version filled each color with a different image, that makes the magic of FF
The magic of FF is that you can modify more things easily and add things that it may not be possible in other software, for example make a customizable hollow triangles to adjust the size width of the triangles as you may want and also make the holes transparent to see through the background
will put the filter later when solved some problems I have found
