I have just thought and realized now that you can use Photoshop brushes in a way that you can be used with filter forge to make mask and artistic works because they can be used in the way that can be applied to the canvas with transparent background and then exported as an PNG file with alpha
In Filter Forge (FF) then can be imported as an alpha transparent source image or as a selection
I already had put that You can use PSD Fonts Letters inside your filters NOW ! without FF 4.0 where I explain how to do it.
So, in the same way as the letters, you can also use Photoshop brushes in a image and in import it in FF and you can use it as a mask or as a shape to create things, either using colors or filling it with other source images or even other photoshop brushes.
I will modify my own Alphabet creator filters to use this photoshop brushes
well, really, you can already use now the available ANY FONT versions to load also photoshop brushes as PNG images, but these uses the normal bomber and is limited to just only 5 input
Of course that what I have told above is true to be used with any kind of Photoshop brushes
But I have had the idea just now of this because of the awesome and amazing images using artistic brushes inside FF Paintlab examples by emme
As I have no idea how emme have done it, I have thought to fake it using external source images and my own filters
Mainly also because I have just found today (with a 50% discount) these artistic brushes
Awesome Brushes Vol.3 that simulates realistic brushes strokes by Zsolt Kosa
In the previous Paintlab by emme link, please scroll up to see the first Paintlab 01, as the link goes to the Paintlab 02, sorry for putting the wrong link
And also these other realistic splatter and splash (also at 50% discount today)
150+ Photoshop Splatter Brush Bundle by Zsolt Kosa
where there are lots of realistic artistic ones
and more and without the bundle here
Or also using Ink to create artistic effects
InkyLeaks - 100 Splatter FX Brushes by GrutBrushes
USE ALREADY MADE PNG WITH ALPHA AVAILABLE
As these Photoshop brushes need to be converted to PNG and you need Photoshop to do it, there is also another alternative that does not need Photoshop or converting any brushes and is to have the PNG files already created and ready to use
Here for example are some paid ones that are professionally done
487 Isolated Ink Strokes & Shapes
There are also many free ones available on internet
USE ALREADY MADE BACKGROUNDS THAT YOU CAN CONVERT TO PNG WITH ALPHA
AS another alternative is to be able to use professionally created backgrounds that could be used and converted to PNG with alpha to import into FF
Splash Luxury Paint Backgrounds
Yes, you can make brushes in most graphic programs, a good thing to know. Long ago I created a filter that can use these brushes for painting, Brush Engine Van Gogh.. I've also provided some free brushes to play with:
http://duim.com/filterforge-DRVG/brushes/
Username: filter Password: forge
Here is an additional way to use external brushes. I'm providing a filter here that I probably won't release, it is pretty slow. It's a modification of Impressionist Curve using external brushes only.
FF 7 and above. The results are amazing but slow. It curves the externa; brush.
Impressionist Brush.ffxml
And an example of Impressionist Brush and the used brush.
You can also use this the other way as well...You can create in Filter Forge and create brushes for PS..........Did these many years ago.....
Tech Circles
External brushes (or any image file with transparency) may also be used to create more artistic patterns. The external and internal brushes may be mixed for more variation
OH!!! WOW!! I did not know and have not seen that in this filter you could be able to use external brushes and this has been done thinking of this. Very good to know a dthabks for putting it here
I will test it and see what can be done
Thanks for this, and will try it and how it works and how slow is it
Oh, yes, of course that you can also make brushes from the FF results, good work
LOTS OF FREE PNG TRANSPARENT ISOLATED AVAILABLE
If you do not have Photoshop to use the brushes, there are a huge amount of websites that have isolated PNG graphics with transparent background
For example if you search in Google for splatter brush png isolated there are many free websites that have PNg to download and use in FF filters.
Here is one website that has a huge amount collection of free to download PNG transparent that are high quality
9 Grunge Banner Brush Stroke Splatter (PNG Transparent)
or to use realistic brush strokes inside FF you can use for example these very well done free ones
44 Grunge Brush Stroke Banner (PNG Transparent) Vol. 3
If you scroll down in these 2 pages (here and previous post) to where is put You might also like: you will see LOTS of links to other pages with similar content of PNG free to use
also these cool and well done stains that could be used with FF overlay blend mode in bomber for example
16 Coffee Stains Splatter (PNG Transparent) Vol. 2
Apart fr om these ones, there are LOTS more if you scroll down the page to wh ere the "You might also like" appears
By the way, for anyone that may not know it, to download any of the above ones from this and previous two posts, when you click on the link the full image will open on a new tab and you only have to right click over the image and choose "Save image as"
and the last example is these realistic bold big brush strokes
14 Grunge Brush Stroke Banner (PNG Transparent) Vol. 4
More of them available as this is the vol.4
Please See the 4 previous post for free PNG Brush Strokes to use in FF
All the above ones are to be used personally and can not be used to make a filter to submit to FF library as it is not allowed external images, so if you want to use already created realistic brush strokes in FF, I have found these ones
Paint Smudge by Predatorkind
Expression Square 2 by CFandM
Sketchy Painting by emme
will put more if I find them
