lbs
Hello, I need help with the Postage Stamp filter. I need it edited to include each side of the image to have the same sytle perforation. Right now, I find that 3 out of the 4 sides are alike. The one side that isn't stands out and ruins the look. Please contact me here if you would be willing to work on this for payment. We can discuss the payment. Thank you.
lbsutton
emme
This modification should fix the issue.
Postage stamp (mod) v001.ffxml
lbs
Hello, thank you emme, I have no clue what to do with the modification, so I am reaching out to pay someone to do this for me. Are you interested in the task?
Thanks, Lois
emme
You should be able to download the ffxml file and open it in FilterForge. You can also send me an email and I'll send you the file.
lbs
Hello emme, after I open it in Filter Forge, what do I do with it? I do not know how to much but use already created software. Thank you so much for trying to help me.
Lois
lbs
The attached screen shot is what I get when I click on the link you sent. It's in code.
Lois
lbs
Lois
emme
Try right clicking on the ffxml link and there should be an option to "save link as", or similar, depending on what browser you're using. After saving the file to disk and you can open it in FilterForge.
Yes, as emme have said, the best way is
1 - right click over the link and then download link, or save download link as...
2- Go to where you downloaded the file and double click on it and it will be loaded inside filter forge
3 - Inside filter forge it will appear in the my filters folder with the same name as shown here on the forum
lbs
OH THANK YOU THANK YOU THANK YOU!!!! IT WORKED, IT'S THERE, NOW I WILL TRY IT WITH MY IMAGE.
I CAN'T THANK YOU ENOUGH?!!!!
LBSUTTON
emme
No problem smile:)
17 unregistered users.
