Hello, I really love and like much the 17 WALLPAPER GROUPS MADE BY RACHEL DUIM AVAILABLE IN FF LIBRARY and they are very well done, but there is something I think could be improved and make it even easier, and is to have an option to have a zoom of the seed that will be used for the tiling as now it is small and is tiny to be able to position correctly the image source using the settings
I have already done it myself and have tested it here and it works and so you have now two options 1 - original seed view size 2 - new zoom of the seed view that lets you see it better and easier to position the source image Rachel, I can do the conversion of your 17 wallpaper groups if you like the idea and you are interested in adding my zoom idea, and then I send you the filters modified so you can send them from your account. I can use FF 4.0 or 5.0 so it is kept available to many more FF users and do not convert it to FF 9 that would reduce the amount that could use them. here is the filter for you to test and see if you like it, there are two presets for you to see the difference thanks Wallpaper Group 10 p4 Zoom Seed.ffxml |
| Posted: May 29, 2020 4:12 am | ||
Good idea. Luckily FF 5 still works in Windows 10 (but not in OSX), so I'll go ahead and do the work. You'll see the whole series updated when I have the time.
| Posted: June 2, 2020 2:55 pm | ||
Thanks really very much for converting already all your filters with my idea and great that you like it and you have it added it to your awesome filters
Now you could also convert your other newer filters the Six Pentagon and the Koch Snowflake |
| Posted: June 7, 2020 2:53 pm | ||
Sure, there are a few more to do... but not Koch Snowflakes, it doesn't have a seed
Most of them will just be a scale adjustment, zoom probably not needed. Probable list to update: Six Pentagons, Octoflower, Heptaflower, Hexaflower, Pentaflower, Quadflower, Triflower, N-Uniform Tiles Set 2 Math meets art meets psychedelia. |
| Posted: June 7, 2020 3:19 pm | ||
