Hello, Have you thought about upgrading, updating or adding new features to any of your old filters that was done with old versions of FF and that it was limited to the features and options available on that time and in that version?
Maybe you wanted to do something else that it was not possible with that FF version so you only did what you could but now with the newer versions it would be possible to do it Or maybe with newer FF versions it could be better, more simpler or faster than when you have done it, or you could add or modify some things that was not possible with that FF version I do not mean that you replace and remove the old filters if you do not want, as this would make that some people not able to use it, just make a new upgraded version that justify it. Loops and Recursions Bomber plus other Plus components the new greenified mappable components new PBR support these 5 features have changed much on how filters may be done and what is possible to do Also in FF 9.0 there now the option to create PBR textures so it could be now add a PBR version of textures I have seen some filters that would be better now to use Loops that would simplify much the filter WHY I PUT THIS? I put all this because now I have just realized that I made these filters shown here below on the screenshot with FF 3.0 and they allow only to use 5 custom letters that you can choose and was really wishing that you could be able to use ALL 26 letters, but the bomber only had 5 slots, and combining bombers was not giving a good result. BUT NOW is already available the bomber plus that does not have the 5 limit and so I just realized that I can do now what I wanted to do the first time and could not do it Do not know why since that bomber plus was available I did not thought about this, and so I thought that maybe some of you may have done a filter with a idea and what you wanted was not possible at that time but may be possible now |
| Posted: March 8, 2020 3:38 am | ||
