You already may know that the Tiles component has a Jumble option, but what if you would like to have an jumble option for noises components?
Well, Sharandra already thought about this and Indigo Ray shared a possible solution to this
In the thread above the filter available is without any controls, so Here I put this solution with additional basic simple controls that you can use if you want and think is useful and cool
It could be added more additional options and modify it as you may want
For example:
1 - have edges on the cells
2 - be able to move and offset the source image to move it around the jumble design
3 - Be able to choose the noise component that may want
4 - Have additional controls to modify it further
5 - Combine two of this and so you can combine two jumbled images into one, or even 3 images
6 - Makes stripes and jumble them
7 - Do not know yet, if it could be possible to combine different noises (2 or more noises) to make one jumble over one image
and other possible things
Will put later an advanced version with more options
This filter is for FF version 8
worley jumble with simple controls.ffxml
here is a simple example with the FF Kingfisher
I have just discovered the amazing works of the famous and popular artist Michael Albert that makes huge collages with cutout letters from magazines and products and for the topic here, he is able to deconstruct a simple cereal box into an artwork
For example this one shown here
And here is similar source image used for the above one
And here is the original image that he has uploaded to Pinterest with other thousand more of his work
And I remembered about this here in FF that maybe could be done something similar with FF and deconstruct images
Hi SpaceRay, I forgot that I made that filter!
Here is an example that looks more like paper cutouts, with a drop shadow.
Unfortunately the pieces in the filter don't have the same sharpness / triangle shape as the artwork you linked to.
(on a side note, oh my god I cringed at "cerealism"...)
Yes, you did it, and is really awesome that may be possible to jumble irregular ones instead of only plain tiles squares.
OH!! This looks much better if you have optionally a outline and drop shadow, very good and interesting, Thanks very much, I will wait until you can show how you have done it.
Although I think for my personal taste that for me is better to have them more tight joined than having a gap between the different parts.
Well, I did not want or need that the shapes created are similar or equal to those triangles shown in the example, it was just a possible example I found, and other collages made are not using these same triangles. I just choose this one because it was more recognizable. If you could make it is good, but if not is also good.
I have just seen that I forgot to upload here the newer version I have made with outline edges and more controls and it has 24 presets (it shows also that you can have jumbled stripes either vertical or horizontal)
This one is using the Cells component, but it could be changed to another noise component
This is for FF 9
worley jumble with controls outline edges.ffxml
DJI
Official Bologna Tester
Filters: 257
Very interesting. I downloaded the Froot Loops image and ran it through this filter. smile:D Maybe you could double the noise and blend them together, vertical on top and horizontal on the bottom. See what that looks like? smile:)
DJI wrote:
I downloaded the Froot Loops image and ran it through this filter.Maybe you could double the noise and blend them together, vertical on top and horizontal on the bottom. See what that looks like?
thanks and great that you may like it and is great what you have done
I will try what you suggest and see what I can get
I want to thanks again to Indigo Ray for this awesome filter and I have thought about this again, because I thought that it could be used maybe for creating a zentangle stripes like for example similar to something like this here below that I have found on pinterest
Just an experiment... not that great...
Not that great? is really very much better that what I have got because I was totally wrong on how this filter works and process images
If you mean that is not as great as the example I have put above, is true, but I think that in the above example is included different inclined lines inside each Big polygons Edge shapes, so maybe you could feed this you have done to another
Here's some refinement. If you like it, I will refine it some more, otherwise I'll post it here and move on to something else.
WOW!! This is really much better than the previous example and is an awesome refinement, YES, I like it much and congratulations for having such skill and expert knowledge of FF to be able to make this.
And maybe I think perhaps also alternatively that it could be great to have a full image overlay over these beautiful and great stripes result you have shown.
These suggestions below ARE NOT required and is only just only a possible suggestion, and is just only if you can and want and with the above would be enough if you can not
By the way, what you have done remembers me of another idea I had to simulate these stripes lines art as shown here
I really do not know and have no idea how you have made it and if it may be possible or not to add different custom colors to the stripes you have made so well, and if it is not possible does not matter.
I have to say that your result is better and like it more than this example shown here above so I prefer yours
Here below is another example of colorful stripes, although is just a possible idea and is not needed that you do it if it may be difficult or complex to make as I really do not not know, and this below is not what I want, is just a idea to show multiple colors stripes
Here is a colored example
One with mixed hatch lines and circles
One with all circles and aligned cells
WOW!! This is really great and very well done, and looks good. Thanks very much for making it and congratulation for being able to make it possible and I admire your FF knowledge to do things. Although from my point of view it would look better in black than gray, but of course is your own design.
I want to see how you have been able to solve and make the stripes rotate in the different random directions
There is something I do not know and and want to ask, do the stripes have just one custom color and the grey shown is the background? Well, apart of the polygonal lines of the enclosed shape that are not the background.
I mean if it the stripes have two custom colors?
Cool and great that it could be possible to change also the shapes alternatively, and not only have stripes, well done
Thanks really very much for your work and time involved and is much appreciated
Of course it be will easier to see with the code on your computer. I'll try to release it this week. But for now here's the rough outline.
Cells with Flat and Solid Fill -> Tone Curve using a Noise Curve -> bank of Thresholds to separate out the cells into 10 different sets. These 10 sets each have a separate color and hatch direction. The Background Color is the same for all. There are also edges between the cells which is the Edge Color.
To make it more complicated, I added the number of colors as an option, either 1,2,5 or 10 colors. Just for the heck of it.
You're welcome. I may work more on the circcle hatching, but you get the idea.
Please, take all the time you may need and want, there is no hurry, and I appreciate much the time taken
Oh!, thanks much for explaining it and I can see now that is much more complex than I may have thought and that really the stripes hatch are not rotated randomly, you have already created 10 fixed sets yourself, and so explains why it looks so good and well done. Awesome and great work and also for adding the colors option
