Filters: 711
I was thinking to use a Bomber or a Bomber+ to make sticks that start from a center.
Filters: 711
I get this result.
Filters: 711
I was wondering....... If the V Chaos is 0, why do the sticks don't begin from the center?
Here is the file.
test rot.ffxml
Filters: 711
If I detach the free gradient there is no rotation, and they correctly stay at the same distance.
Ok, confused me for a moment. First, set Density = 1. Then, after some thought, I realized that the gradient going into the rotation is a "global" map, not per particle. So each "line" is rotated according to the global map at the center of each row (4 in this case) within the rotation map. Then increasing density then creates additional line offset by the internal algorithm. Does this make sense?
UPDATE: An additional problem is the 0..1 space for the bomber particle. When rotating it, there is no way to get the sticks through the center. I would use Loop to do this like so... (FF7 and above)
test line rotation.ffxml
Filters: 711
Thank you! Good idea. I am not accustomed to use Loop. But it is useful sometimes, also because of the Randomizer.
I made a filter with lines, but I used a different solution.
mitaywalle
Great to meet you :)
Filters: 63
When you increase bombers Density it add points between existing, so if Density = 1, you've one particle, Density = 2 you've 5 particles , 1 at center + 4 to between center and corners.
You can limit opacity radius, and get rounded lines.
Randomize everithing!
mitaywalle
Filters: 63
ordered lines continue eachother
mitaywalle
Filters: 63
Adding Bevel to ellipse can add sphere-like look
mitaywalle
Filters: 63
disordered
mitaywalle
Filters: 63
if you need to not cross center you can use Center X / Y and some math to get least distance to center, to hide
https://imgur.com/a/wbdNW7w
filter for experiments
Lines from center.ffxml
mitaywalle
Filters: 63
some examples
mitaywalle
Filters: 63
example
mitaywalle
Filters: 63
example 123
Filters: 711
Interesting results. Thanks mitaywalle. You gave me some new idea for a filter. smile:D smile:D smile:D
I agree that these are interesting results and useful to know how this can be done
Thanks mitaywalle for sharing this and for the way it is done
23 unregistered users.
