ddaydreams
Frank Hawkins
Is there a FF filter or snipit utility for determining the percentage of black in a black and white image document?
Here's a picture of what I'm after. I just made up the 35% figure. But that's a good example of the simple looking percentage readout outcome I would like.
ddaydreams
Frank Hawkins
You can't see how much of doc is white because it's on white background on this forum. But I trust you get my meaning
Sphinxmorpher
For a simple determination of intensiry you can look at the inverse average color. Here the result is 0.33 (or 33%). If you need it to react only to pure black, you need to preprocess with threshold and use a blur at max. radius
ddaydreams
Frank Hawkins
So I'm trying to determine how much of the space as a percentage of a pure white document is used by the pure black circle I added. I was not concerned about the intensity. Are you saying the intensity has something to do with figuring that out?
Sphinxmorpher
Maybe I misunderstand - do you actually want to render that red text saying "35% Black", or do you want to get the numeric value 0.35 inside the filter for use in another context?
The the black disc is 24.6% of the image, not 35% smile;-)
ddaydreams
Frank Hawkins
Thanks, Sphinxmorpher
Inside or outside the filter is fine I just needed visual access to the figure without having to do the math formula of determining the surface area of the black and deducting that from the surface area of the whole doc to get the percentage of black surface area involved in the document.
Such a math formula could get pretty tricky on(let's say)a black and white reaction-diffusion image.
So this will work for me I think what you've done here yielding the 24.6% equivalent figure provides me with a way to have the number I'm after on any image.
The purpose of the number is to tell me when a complex black and white pattern has a surface area that is 50 percent black and therefore 50 percent white (aka balanced)
rather than just eyeballing it.
Thanks Much
Sphinxmorpher
Yeah, the trick is really to disregard the complexities of shapes and patterns completely and simply look at the total average. If it is greater than 50% (gray) you have more white image etc.
