Hello, I have been trying to find filters that may use the Ramdomizer slave component that is available in the Bomber Plus component, but have not found any yet
Please, I want to ask to any of the FF users and contributors, if you may know what filters include and contain this randomizer with bomber plus?
So this way I can see how it is being used, and learn more about this to use it on creating filters
Do not know if other plus components have also randomizer slave apart from bomber plus, I mean that I would like to know any filter that uses the randomizer in some way
Thanks very much for any possible help
Impressionist Curve
I use the Randomizer for the Hue, Saturation, and Lightness variation. Hope this helps. smile:)
Thanks Rachel, will see how you use it
emme
This uses about 20 randomizers smile:)
InterFacer v007.ffxml
Thanks emme or your help, will see what you have done
Thanks very much for any additional help and anyone else that knows about any other filters using randomizer slave
Well, I have finally tested these filters and they are very good
Surely the best and what I was really looking for in some way is what the awesome and amazing Interfacer v007 from emme is able to do, lovely and very good and well done
Thanks a million emme for making this very helpful, useful and impressive way of using bomber plus and lots of randomizers with different shapes
Now thanks to you, I may be able to understand how can I could multiple different random results from bomber, will have to make some more tests, but this is an excellent starting point
All the best for you emme
Also thanks to Rachel
