Janeway
| Posted: October 21, 2017 5:24 am | ||||
Janeway
| Posted: October 21, 2017 5:25 am | ||||
Janeway
| Posted: October 21, 2017 5:30 am | ||||
xirja
Increase the distortion amount or reduce the scale on the noise distortion component?
| Posted: October 21, 2017 9:51 am | ||||
Janeway
| Posted: October 22, 2017 7:52 am | ||||
xirja
Not seeing the filter, and seeing the above image, my suggestion would be to use a loop and offset each particle a random slight amount. It appears you want the circles to be round in shape, so noise distortion is probably not what you want to use. Pay attention to the different Variation settings on the Randomizer nodes, which by the way, on the final group offset should be 7 and 8.
LoopOffset.ffxml _____________________________________________________
| Posted: October 22, 2017 11:01 am | ||||
xirja
Test
![]() _____________________________________________________
| Posted: October 22, 2017 11:09 am | ||||
Janeway
Thank you so much!
I am new in using loop, but I would like to study it. You helped me really lot! I try build in it to my filter soon. Tomorrow? I hope. Can I use this sequence in my filter? I am confusedly because of I can see that filter is created by dimitrivorkapich but you uploaded it. Who may I credit it for? |
| Posted: October 22, 2017 12:18 pm | ||||
| emme | ||||
| Posted: October 22, 2017 12:55 pm | ||||
Janeway
Thank you so much, emme! It looks fine too.
| Posted: October 22, 2017 1:01 pm | ||||
xirja
Oh yes, the good old origin and bomber trick, of course emme, you nailed it! My Sunday stumbling, but learning to use the loop is helpful too.
| Posted: October 22, 2017 1:41 pm | ||||
PayPaul
Posts: 106 |
Which component is the randomizer? What category of component can I find it under?
Don't step on a dead dogma. It'll turn up again and bite you! |
| Posted: October 23, 2017 6:45 pm | ||||
xirja
It is an optional sub-node of the loop:
| Posted: October 23, 2017 6:51 pm | ||||
PayPaul
Posts: 106 |
I've seen now how that is created. What, then, does the Loop component get connected to? What is a proper accumulator component to connect to the 4 loops I add to then produce those 4 randomizers? Can only one accumulator be connected to all four loops?
| Posted: October 23, 2017 9:16 pm | ||||
xirja
Perhaps you'd like to create a new thread/post to address whatever issue you are having with the loop component?
| Posted: October 24, 2017 7:23 am | ||||
Janeway
| Posted: October 29, 2017 8:58 am | ||||
Janeway
| Posted: October 29, 2017 8:59 am | ||||
Janeway
| Posted: October 29, 2017 9:00 am | ||||
Janeway
Janeway
I just realised that I like that "Not bad, but not exactly..." It would be possible to do something with this. And I deleted it earlier!
| Posted: October 29, 2017 9:29 am | ||||
| emme |
Hmm, it seems like you are inputting a static image into the color of the free ellipses. That input wont move with the x/y origin of the ellipse, so the ellipse is just acting as a mask - blocking out part of the input image. You could use the bombers center x/y sub-components to offset the input image accordingly. I dont really think you need to use image input here though - you can just use a single color per ellipse to build up the shapes.
Also you might want to limit the min/max settings of the randomizers, so that the ellipses wont move too much. You can check my settings here: CircleBomber v001.ffxml |
| Posted: October 29, 2017 11:01 am | ||||
Janeway
Thank you, emme.
I have Filter Forge 5, I can't try your filter.
Nowadays I have really little time, but I will try your suggests, but I do not know it when I will do it. |
| Posted: November 9, 2017 2:48 pm | ||||
I have just found this thread looking to make non concentric circles in FF, as it is very easy to make concentric ones, but to have random offset of the circles is not so easy to find out, and with great and very useful help of xirja and emme I have seen a great way to do it and will try
Thanks also to Janeway for asking this question Here is what I want to do, use the bomber plus with randomizer and loops to make this art that is based on the PI Feynman point art |
| Posted: February 25, 2020 2:50 am | ||||
| Posted: February 25, 2020 3:03 am | ||||
| Posted: February 25, 2020 3:05 am | ||||
| emme | ||||
| Posted: February 25, 2020 9:43 am | ||||
WOW! Thanks really very much for sharing this excelent, cool, awesome, clever and great interesting spiral that is really well done and like much how it works amd adittionally you have also used these offset non-concentric components and used the concentricity setting for adjusting Thanks really much for taking the time to do this and that is much appreciated, it works great, good also to learn more |
| Posted: February 26, 2020 11:16 am | ||||
33,846 Registered Users
+13 new in 30 days!
+13 new in 30 days!
+44 new in year!
