Administrator |
Mosiac --> Mosaic?
http://www.filterforge.com/filters/322.html CFandM, you can submit updates to your filters, but be careful -- since you're going to change the name, the Submit Wizard will deselect the the "Update" option -- you'll need to select it manually, then choose the original filter, Mosiac Rock. The filter itself is cool! |
| Posted: May 28, 2006 4:35 pm | ||||
Thanks, coming from you that makes me very estatic about making it in the first place. I'll update it quick as I can.
| Posted: May 28, 2006 7:45 pm | ||||
Well, I fixed all the typos then sent the update. I waited a few minutes
then opened filterforge to go look at the update and it had updated but then changed to the old version. Do these updates also wait to be looked at? Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: May 28, 2006 8:10 pm | ||||
Administrator |
Yes, updates also go through the approval process -- which is currently VERY slow due to techical reasons. I've approved the update -- look for it in the Updates folder in the Library window. |
| Posted: May 29, 2006 3:31 am | ||||
30 unregistered users.
