grue
hello. i'm brand new. downloaded yesterday. so far i love it. i'm using FF to create maps for 3d models. diffuse, normal, etc... i just discovered that my new filters don't all have to be 600px by 600px ha! i can make them 4800x4800.
anyway, so in 3d, i have a 10ft tall 10inch diameter concrete column inside an old warehouse that i want to texture with a diffuse map and normal map.
i have created a filter which "adds" A&B, A&B are noises.
the concrete column is pitted, in other words, there are chips of concrete that have fallen off over the 60 years this building has been around.
what i am going for is to create normal map for showing those various chips and pits. but, i don't want to have too many of them spread all over the place so it looks like it's structurally unsound ha!
i've attached images showing the filter i came up with, then i photoshoped a copy to show fewer overall pits/chips, then attached what the filter looks like.
so my question is, what's the best approach to creating a mostly flat, but tileable filter with a small number of pits/chips?
thanks!
grue
here is the desired filter "look" - the above one is what i have so far.
grue
here is the filter in FF (which results in the top image)
EDIT: the gradient background is just something other than the bright pink background when there is nothing in the surface color
try some Noise component into the "Noise" input of all the three noises. Something with low roughness, high contrast
grue
thank you sorry for the late reply!
