kumarspain
Posts: 3 |
Hi Good Morning...
my name is kumar and Im knew to filter forge....which i like very much...Happy to be here. still in my startings and trying to make a frame that has as material : MARBLE look is very difficult to make it ?? with some reflectivity and a bit of 3d ?? thank you in advance, kumar |
| Posted: August 9, 2017 8:22 am | ||
Check out this filter... It has a marble frame.
https://www.filterforge.com/filters/4707.html |
| Posted: August 9, 2017 11:11 am | ||
kumarspain
Posts: 3 |
Hi Sphinx,
thank you very much for yr fast reply...beautiful marble chess. Unfortunately i need to learn more cause seems hard to understand how to make it. is any book from where to learn easily to make filters ?? it seems that to make filters is a long process of controlled events to reach a final result...for me all is new and no explanation of how to use filter editor commands anyway thank you very much for your assistance.... kumar |
| Posted: August 9, 2017 4:32 pm | ||
I would suggest maybe starting on something simple first just to get used to the editor.....Open this Frame Filter in the editor and see how it is made....Mess about with this one and then go on to other frame filters to see how those are created....
| Posted: August 9, 2017 10:43 pm | ||
kumarspain
Posts: 3 |
thank you very much CFandM.....already seen the filter...will go through it....but anyway will like to say that if Filter Forge can add a PRINT option to the Editor will be nice....for starters like me will be more easy to learn ....if can copy and paste all the little windows that compose a filter to Word for example....i can make a printout in din A4 and follow it with more detail....
thanks again, kumar |
| Posted: August 10, 2017 3:12 am | ||
16 unregistered users.
