Chin Rey
Filters: 9
A quick question - or possibly a very complicated one... smile;-)
I need to split an image into several horizontal strips of uneven heights and process each of them separately. There must be a million ways to do the splitting in Filter Forge but which of them is the most efficient?
chrisd
I did a search for "scanline" in existing filters. There are quite a few, maybe some of them use a method that is close to what you are looking for.
I noticed that the rendering option "Anti-alias sources for bitmap-based components" has a huge impact on the rendering time for certain filters. In particular Wavy Neon Lines, it goes from 10 seconds when off to 90 seconds when on for the default preset.
xirja
Idididoll Forcabbage
Lookup would be my guess. Maybe Free Rectangle to Threshold. rgba is 4 channels, so if you can eliminate the alpha, it'll be faster as it is only 3. This might help: https://www.filterforge.com/wiki/index..._for_Speed
chrisd
Thanks for that, I have a look at the wiki. I have a lot to learn, but having an active forum as this seems to be will help a lot.
As xirja said the free rectangle and threshold works...Are you doing this for one image or is this for a part of a bigger filter...Then do you want to control each strip individual or have them size automatically?......Here is a simple one using free profile grad and threshold....
Here ia simple version with one strip that can be adjusted manually...
This is for FF6...
Simple Thing.ffxml
The "Anti-alias sources" checkbox is effectively a "Slow me down" option. Please check the corresponding help section:
https://filterforge.com/more/help/Opti...tions.html
Chin Rey
Filters: 9
It was more of a general question. It's a function that is useful for so many filters and I've needed it several times recently.
I've seen several filters using a gradient and I think that is the most common method. A free gradient is listed as ultra-fast in the wiki but you have to run the output through a threshold component to get a sharp edge and that may slow it down.
Thank you. I have to look up the Lookup component, I'm not familar with it. I was actually trying to use a frame, scaled, squashed and with y offset the same way as you suggest we use the free rectangle. I suppose the rectangle is the better option.
