Stage5
Hi Everyone,
I posted a question a few weeks ago about scaling a texture for an existing filter.
https://www.filterforge.com/forum/read...sage145170
I never got an answer, but I figured out how to do it (I thought), but now I've realized that it broke the seamless texturing. Which is something I need for a project I'm working on. All I did was add a scale node between the "Blend" and "Result" node and entered "3" for the "Scale" entry box instead of the default ".33".
I would attach the modified filter file, but for some reason it won't attach at all. I tried both a zipped version and the plain ffxml file. I would also link to a picture, but never could get the link from my Flickr account to show it here. ?
Does anybody have any ideas what is causing this?
Thanks in advance for any assistance with this, it will be greatly appreciated.
Edit:
Ok, I should have RTFM. I see that the scale component doesn’t work for seamless tiling. Looks like I'm going to have to render the full size image (36"h x 60") x 3 to get the pattern I need. I was trying to tile this texture so I wouldn't have to do this. The max size of the pattern in the original filter texture is too small for my needs.
Stage5
So here's another question about this. If seamless tiling is disabled when a scale node is used, why is the checkbox for Seamless Tiling still available in the material settings?
