Zoltan Erdokovy
The wave curve has a phase param, which shifts it around. Can I do a similar thing with an arbitrary curve? Wrap around would be important.
| Posted: February 12, 2007 10:59 am | ||
Administrator |
Yes, the Phase component can do that:
http://www.filterforge.com/more/help/...Curve.html |
| Posted: February 12, 2007 11:14 am | ||
Administrator |
Or, if you want a wrap-around, use Repeat:
| Posted: February 12, 2007 11:15 am | ||
Zoltan Erdokovy
Cheers!
FYI: I made two phase nodes. Each eats the curve I want to shift back and forth. Their phase value is controlled by a slider. The sliders are remapped to the range of [0,100] and [-100,0]. Finally a math node adds the two phased curves together. When I move the slider the curve starts to move to the right and enters on the left, until it moves a full cycle. |
| Posted: February 12, 2007 1:02 pm | ||
16 unregistered users.
