LexArt
LexArt
Hi, I do not know if it is already available or not
I have seen that ThreeDee made already the very good and well done Image cube rotatable and Rotatable sphere
But what about a simple 2D flat plane with a source image that could be rotated in 3D space, so you could then build composition with falling 3D images like shown in the image below
I suposse and think that would be easier to make than a cube or sphere, althogh I do not know
So if you could rotate an image in 3d then you could render them and build compositions like this google images search about falling cards made in photoshop
Thanks for any help
It is very easy to achieve with just a couple of components:
Rotated Plane.ffxml
Well I have not seen any filter like this, but I have made a special one for you based on the ThreeDee 3D cube using the cube sides separated with a bomber as shown on the falling cards examples
I do not know if this is what you want, as I do not know how to make a simple ONE plane, as the filter given by ThreeDee above does not have any settings
Be aware that all the images of bomber will be rotated at the same time as they are all based on the same source
If what you want are single rotated planes, you can try to use the input of the bomber if you want before they are entering the bomber.
I think that this filter has a good potential and I may be able to make a further better version with individual rotation and multiple images sources once I understand how it works
2D Image plane 3D rotatable Bomber (2).ffxml
LexArt
LexArt
Thanks ThreeDee for making an example but it does not have any control settings and I do not know how to use it
Thanks very much for your help and for taking the time for creating this filter for me. I did not want to ask for a complex thing, and this is why I asked only for a simple 2D plane rotatable and then I could just render it and make the composition on Photoshop or use it with the bomber as you have done and how is shown on the examples I had put.
It would be good if this could have multiple images
A couple of controls added.
Rotated Plane w Controls.ffxml
LexArt
LexArt
Thanks ThreeDee will try it and see how it works
