paulcopeland
Paul from Australia
g'day fr om Australia.
It takes a great deal to amaze me with computers, but I am gobsmacked with the power of Filter Forge.
I am starting to learn how to use the editor and hope that some kind soul can assist me here.
I want to remove the background wh ere applicabl so that the background is transparent.
Here are two images taken from a selection of an image created with uberLENS2.5. The image on the left is the image with the background. The image on the right is with the background image roughly removed and now the background is a transparent image.
I hope that there is a reasonably straight forward snippet that could be added to help me achieve this result. I would like to add the snippet to remove other backgrounds with filters also.
Could someone please advise, and if the snippet is not too difficult to create, then perhaps you could create the snippet for me and add the snippet to the snippet filters. Thank you.
Paul.
Winner Jean Bogan Piano Composition Competition 2016
Hi Paul,
Add the following components to the filter.
You don't need to duplicate the Kaleidoscope component, it was just easier to show it this way. The kaleidoscope is connected to the same Source as the original one in the filter. You can connect the Threshold directly to the existing Kaleidoscope instead.
To make it transparent you need to either do this on a photoshop layer (not background) or create a new transparent image in the standalone version (set alpha to 0).
TD
paulcopeland
Paul from Australia
Hey ThreeDee.
Many thanks for taking the time to respond with great graphic.
I will try your suggestions very soon.
Wow, 111 filters. That is a bit unreal.
I will have a look at them now.
Best wishes and keep up the great wrok.
