Hi, I know that one of the features of bomber plus is to be able to randomize input feed and that you can change and randomize for example multiple colors,
Well what happens if I have a filter that I have already created and what I would like to use the randomize slave to change the variations slider value automatically?
( I mean the one that is together with the Size, pixels)
So for each feed into bomber plus, it would give a variation result from the filter I have
Sorry that I still do not know much and understand yer how the randomize works, so I am trying to learn what can be done and what not
Maybe it could be easier if the filter itself I want to feed may have a bomber and then I could plug the randomizer slave to the bomber variation slider
I will see more examples of how the ramdomizer is already used in other filters to see how it works and how it can be used
Thanks for any comment, suggestion and help
Quick answer: nop.
This is why we've been asking for FilterForge to make those gray component inputs green which can really shape what we can do in FilterForge.
Thanks for your answer, I understand and know what you mean as I have seen this request in another thread, good to know
13 unregistered users.
