HI,
I want to make a filter that needs to rotate a shape, but when using the rotate component it tells me that the seamless tiling is disabled, so I wonder if there could be any other possible way to rotate a shape or a result, without having to use the rotate component.
thanks for any help
DJI
Official Bologna Tester
Filters: 257
Maybe this will help. This is a filter by Uberzev called Any Angle Rotate v1.1. I've used it before and it doesn't block seamless tiling. smile:)
https://www.filterforge.com/filters/1827.html
Thanks DJI, will try it and see how it works
DJI
Filters: 257
Excellent! smile:) I used it in my filter Wavy Neon Lines Photo Effect and it worked great. smile;)
12 unregistered users.
