memetaltin
Posts: 23 |
| Posted: March 24, 2016 9:06 am | ||
What do you mean as "duplicate to shapes"?
Do you want to take this image, selecting only the areas that aren't black and being able to use it? Or anything different? |
| Posted: March 24, 2016 10:33 am | ||
memetaltin
Posts: 23 |
| Posted: March 24, 2016 11:48 am | ||
memetaltin
Posts: 23 |
| Posted: March 24, 2016 11:50 am | ||
Well, the easier solution is to build it.
Using components like Free Ellipse and Free Polygon, you can create practically any shape. Otherwise, if you don't want to build it, just select an area of your picture where the leave/petal is good. You can use the component Scale to enlarge the right area. Then, using Free Ellipse and Free Polygon, you can cover the areas that are not interesting and use Threshold to select it. |
| Posted: March 24, 2016 3:32 pm | ||
xirja
This might be a good start:
Van Gogh Flow Impasto _____________________________________________________
| Posted: March 24, 2016 4:02 pm | ||
| Posted: March 24, 2016 4:05 pm | ||
It is about like the shape you wanted. You also have a control to change the color.
| Posted: March 24, 2016 4:06 pm | ||
Here is a filter combining the previous Petal/Leave with a Bomber, and applying it to a picture.
Petal - Leave Request 2.ffxml |
| Posted: March 24, 2016 4:20 pm | ||
| Posted: March 24, 2016 4:28 pm | ||
| Posted: March 24, 2016 4:32 pm | ||
memetaltin
Posts: 23 |
Ramlyn thank you so much. I don't distribute particles from the center and all the particles soldier like. i need wavy rotation.
thank you. particle_aboriginal.ffxml |
| Posted: March 24, 2016 4:57 pm | ||
memetaltin
Posts: 23 |
wav super. thank you so much. you guys are best
| Posted: March 24, 2016 5:03 pm | ||
LexArt
Posts: 256 |
Apart from the well suggested link of xirja above, maybe also it could help these other filters
Thai : Jasmine Rice Design by Ramlyn Brown Rice Design by Ramlyn And it also could be possible to mix these ones with the above Also the rice can be easily transformed into a leaf or made bigger |
| Posted: March 24, 2016 5:14 pm | ||
For memetaltin :
You can easily change how the leaves are distributed. Open the filter editor and look at the Bomber component. All what is connected with the Rotation input defines most of the leaves position. There are clearly also other factors, as Variation, Chance, etc. that can be useful to control, but in your case I think that Rotation can be the most important. In my example I connected gradients. Changing the values of these gradients you can make the leaves dispose in many different ways. You can also connect something else instead of my gradients (Image, Free Polygon, Cells, etc.). LexArt posted the links of two of my filters. There you can find another example about how to manipulate the distribution. For LexArt : Thanks for posting my two filters as example. |
| Posted: March 25, 2016 5:41 am | ||
memetaltin
Posts: 23 |
Thank you Ramlyn. big master
Thank you LexArt. |
| Posted: March 25, 2016 6:00 am | ||
12 unregistered users.
