LexArt
LexArt
Hello, I am learning how to make things
Maybe the title should be better
"How to make a specific variable GRID with rectangle shapes with exactly measures?"
I know that one of the new features of filter forge 5 is to be able to have pixel awareness
But I really do not know if this means that you can have things made with specific exactly measures, and I have problems with the pixel grid example of the link above and have not seen any filter using this component
Thanks for any possible help
LexArt
LexArt
Now! Thanks to Rick Duim that have kindly and helpfully made a very good grid filter using the new pixel awareness, available on this other thread now I have started to make it myself and seems to be possible to do what I want
It seems that there is no way to move, offset, flip or rotate the pixel awarness grid, but I can use the well done Line Draw made by Threedee that is found here and with this you can draw and make a line from point A to point B easily, so I can use the Rick duim as base and then this lines draw for the rotated lines
i have also seen these other filters below but hey are always with fixed sizes, and can not be modified, so thanks to Rick Duim I have a resizable one with rectangles instead of only squares
Pixel-Based Grid Snippet by ThreeDee
Grid v2 by Betis
Thanks for any possible help or suggestion
You will be able to see a more advanced version of Pixel Grid in a day or 2. I will release it officially, probably as a snippet. Just taking the pixel awareness a bit further. Then you can look at how I did it and ask questions if you wish.
LexArt
LexArt
Thanks very much Rick, it would be very good and useful.
I have seen that you can´t use with the result of pixel awareness any of these components
Any transform components (Flip, Offset, Rotate, Scale)
Kaleidoscope
Bomber and Bomber +
Noise distortion
It seems that it does not work with any component that will try to modify the pixels positions
