i'd like to have multiple inputs on components. i can currently take something like the 'image' component and plug it into multiple other components all from the same image component. but i cant take outputs from multiple sources and plug them into the same connection on another component. there are some cases where this would be desirable. i suppose you could liken it to a 'blend mode' in a graphic editor.
craig
Processing > Blend. Mixes two inputs together, and has all the blending modes you're already familiar with.
Processing > Switch. Allows you to select from several inputs based on the value of the Selector parameter.
ah, i had seen the 'switch' one, but hadnt tried it yet but completely missed the 'blend' one. i'll give them a try.
thanks, vladimir.
craig
29 unregistered users.
