| KeithS |
hi, I have a filter I just created and I want to upload it but I do not want the wizard to create auto variations because the results are horrible and doesn't do this filter justice.
is there anyway I can avoid this step in the wizard? I couldn't find any info about this topic.... thanks Keith |
| Posted: September 23, 2015 6:59 pm | ||||
Go to the editor and edit your filter. Go to Filter / Overrides... and change Variations to disabled, then OK, then save your filter.
| Posted: September 23, 2015 7:19 pm | ||||
| KeithS |
hi Rick thanks for answering... but the wizard still generates presets even with the over rides disabled.
I am not sure I can stop that upload wizard somehow ? Keith EDIT - I think I figured it out... I need to manually create 9 then the wizard will skip the process.... |
| Posted: September 23, 2015 9:40 pm | ||||
if there is no variations presets made manually by yourself, then they will be created randomly by the submit wizard, as is not allowed to have in he library a filter without any variations, so you can not disable it
| Posted: September 23, 2015 11:16 pm | ||||
Posts: 3507 |
Please check the help file:
| Posted: September 24, 2015 6:03 am | ||||
15 unregistered users.
