| KeithS |
hi all, i don't post often.... but cant seem to figure out something....
lets say I have a wheel and a rim.... i want to control the wheel size independently, and also the rim size independently.....however I do not want the radius of the rim to go higher than the radius of the wheel... so that the user doesn't have to eyeball the limits. so if the wheel is 30, then the radius of the rim can only go as high as 30.... but if the wheel changes to 50 then the radius of the rim can only be up to 50 max. any guidance would be appreciated. thanks Keith |
| Posted: September 19, 2015 1:26 pm | ||
Here is a snippet. There are 2 controls. Control 1 goes to wheel size. Control 2 goes to rim size. The output of control 2 is after the Min component, which determines if the rim size is too large.
1 controls another.ffxml Math meets art meets psychedelia. |
| Posted: September 19, 2015 2:09 pm | ||
| KeithS |
ok super Rick, understood !!! exactly what I needed to know !!
cheers man !! Keith |
| Posted: September 19, 2015 5:43 pm | ||
11 unregistered users.
