tacomalo
Posts: 18 |
Is it possible to generate 3d noise volumes for games?
What I mean is, is it possible for me to modify one of the noise nodes such as to create "slices" of noise that are coherent in the 3rd dimension? for background, 3d volume textures are an array of 2d textures packed into a single file using the DDS format. 3d textures can be used for a variety of effects, one of which is applying 3d noise to a fog volume to create patchy fog. I am using FilterForge 4.0. Thanks. |
| Posted: August 12, 2015 11:38 am | ||||||
in filter forge you can export 3D maps to be used in a 3D software or whatever software that can understand these maps
| Posted: August 12, 2015 1:22 pm | ||||||
| emme |
3d perlin noise can be generated with get_perlin_noise(x,y,z,scale) in a LUA script.
| Posted: August 12, 2015 1:49 pm | ||||||
tacomalo
Posts: 18 |
Thanks emme, SpaceRay, how are the 3d textures exported? as individual slices or directly into the DDS format?
| Posted: August 12, 2015 3:44 pm | ||||||
tacomalo
Posts: 18 |
I tried feeding in a value input to the Z axis of the perlin noise, but it seems to stop working. I can output noise slices from 0 to 3, but then numbers higher than 3 output the same result...
I found this thread, seems like the Z parameter doesn't quite do what I was looking for. https://www.filterforge.com/forum/read.php?TID=12447 |
| Posted: August 12, 2015 4:34 pm | ||||||
| emme |
Testing this out, looks like it's working here. I don't think there is DDS support, so you would have to export the slices individually and combine them somewhere else.
Volumetric Perlin v003.ffxml |
| Posted: August 12, 2015 5:19 pm | ||||||
tacomalo
Posts: 18 |
i was able to get something to work, but i had to muck around with my input value to get something that sorta looked ok.
i started with the example noise from the documentation. ideally i would like to be able to make the noise seamless in the Z direction as well, so my and first last slices lined with each other, but it doesn't sound like the Z axis uses the same scale parameter that X and Y use to determine repeat size... Script API - Seamless Perlin.ffxml |
| Posted: August 12, 2015 6:10 pm | ||||||
| emme |
Yeah, I think you're right about the Z axis. Can't think of any good solution to that.
Let us know if you figure something out. |
| Posted: August 13, 2015 12:59 pm | ||||||
FF doesn't seem like the best tool for it frankly. I would make something similar using AfterEffects. Use the Fractal noise effect, and keyframe the evolve parameter. Under Evolution Options there's a cycle evolution option, that lets you basically loop the fractal noise (you were saying you wanted Z to be seamless as well).
To create seamless textures, you can offset the texture and erase the corners via masking. You'll probably have to convert the set of images exported from AE, later to DDS format. Think this does you best. |
| Posted: August 13, 2015 8:55 pm | ||||||
tacomalo
Posts: 18 |
AE does indeed give me the tiling in the W axis using the Evolution option, but it doesn't tile in U or V.
Post-processing the frames to eliminate seams is not the end of the world, but becomes tedious with a high number of frames. Thanks. |
| Posted: August 14, 2015 4:07 pm | ||||||
| emme |
Also, Houdini has all kinds of periodic 3d noises. Don't know if it supports DDS.
| Posted: August 14, 2015 5:32 pm | ||||||
You can do much of that in AfterEffects anyway. 1. Precomp the noise pattern you made. Make sure the noise layer is inside the comp. 2. Just like how you would erase seams in Photoshop by offsetting, you can offset the comp and do the same. -- Duplicate the precomp and apply an offset effect to the bottom one. Go ahead and offset the image to your liking. 3. with the duplicated precomp, use a mask and draw the shape of the seams. Feather the mask if necessary and apply it on top of the seams showing in the offset areas. That should make life a bit easier. |
| Posted: August 14, 2015 6:43 pm | ||||||
tacomalo
Posts: 18 |
Thanks for the help, Skybase, I made some progress in After Effects, but ran into issues trying to use a Mask on a Noise Layer that has been offset. I abandoned AE, tiling on the X and Y is more important than tiling on the Z, so i'm gonna stick with Filter Forge, maybe add a feature request to make the noise tile-able on the Z axis.
| Posted: August 18, 2015 12:02 pm | ||||||
What were the issues? Maybe I should just make an example file since describing it in words = pretty hard to understand. |
| Posted: August 18, 2015 6:59 pm | ||||||
tacomalo
Posts: 18 |
Hey Skybase, I ran into two issues
1. After creating a sequence of 32 frames for the noise to evolve over, I made a copy of the layer. 2. I Offset the Transform of the Noise to 0,0. 3. I applied a Mask to the Layer 3a. This is where the first issue occurs. As soon as I apply the Mask, the Noise changes. I am not sure what changed about the noise, but it is no longer the same the initial Noise. If I change the Mask from Add (the default mode) to None, the Noise returns to the initial state. Of course, when the Mask is set to None, then I don't have a Mask anymore. 4. The second issue I encountered was the Noise Offset to 0,0 would flickered wildly over the 32 frames. The other 3 copies of the noise offset to the other corners did not flicker. |
| Posted: August 20, 2015 3:17 pm | ||||||
Precomp the noise layer and then apply the mask on THAT precomp if you're using CS6 and below. If you're using any CC version of AE, you can apply the mask TO a specific effect layer.
I'll investigate a bit more. Will upload example today! |
| Posted: August 20, 2015 9:59 pm | ||||||
21 unregistered users.
