Arielle01
Hi,
is it possible to change the strength of the yarns and the distance?
I would like to have thinner lines. and more distance between lines.
Is this possible?
Thank you and sorry for my english
ronviers
lighter/generalist
hi Arielle
i'm sure there is a way. i will look at it this weekend and post something here. do you have the pro version? just curious, we can find a solution even if you don't.
best regards(:
@ronviers
Arielle01
hello,
thanks for the reply. I have the demo version for testing.
Will after the standard version Buy.
Thank you for your support.
ronviers
lighter/generalist
i remembered i had already worked this out on my lockstitch texture so it was a simple matter of adding a couple of lookup nodes. i also added an alpha option for nets/mesh, and a background color option
hth,
ron
Plain Weave_arielleMod-006.ffxml
@ronviers
ronviers
lighter/generalist
just noticed i wired the weave density slider backwards. those things drive me nuts. here is the corrected mod
Plain Weave_arielleMod-007.ffxml
@ronviers
ronviers
lighter/generalist
now i noticed the noise wasn't tiling vertically. that's what i get for rushing it. anyhoo, rather than research it i used a hack to bypass the lookup then apply the noise. not pretty internally but it's an effective workaround.
so i guess that makes this servicepack1, hotfix2(:
Plain Weave_arielleMod-008.ffxml
@ronviers
Arielle01
thank you,
it works very well! ... exactly what I was looking for
ronviers
lighter/generalist
you're welcome(:
@ronviers
