joBox
joBox
Filters: 4
These are probably newbie questions, but here I go:
1) The presets I made look MUCH different than the presets that were rendered and uploaded. Why? And is there any way to fix this?
2) Also, I made 15 presets, but the uploaded version only shows 8?
In the pic, mine are on the left, and the uploaded version is on the right ...
Thanks!
Newbie questions = Always an answer... smile;)
1...By default the presets show the image with seamless tiling checked...So check that when creating the presets....
2....Again the website by default only shows the first 9 presets.......
joBox
joBox
Filters: 4
THANKS for the responses to my last couple of questions ... you rock! smile:)
Anyway, it DOES look like it's a seamless tiling thing (good catch) .... BUT, none of the seamless tiling boxes are checked in the presets I made. When I submit the filter, there's no option to change seamless tiling ... it just automatically renders the thumbnails as if the seamless tiling box was checked.
So I guess my question back, is when I submit the filter, how to I prevent it from rendering all the thumbnails with seamless tiling?
thanks!
You are welcome its something that goes way back.. smile;) smile:) ....I have even done this...Submitted and found out after that I forgot to check that box...Doh!!...
You can use the override in the editor...Don't remember if this setting is save with the filter or if its machine based setting...But try it anyway and find out... smile:)
Otherwise just check that box for all the presets and re-save each one......
Then choose disabled and click OK then save filter..
joBox
joBox
Filters: 4
PERFECT!!!!!!!! Thanks a ton ... that's a very obscure "feature" there smile:)
