filteratha
Posts: 3 |
I need to create a new filter by passing the "Result" of Filter A
to the input "Image" of Filer B. I don't see any input possibilities in the External Image component of Filter B. How do I do it? |
| Posted: June 29, 2014 10:42 am | ||
The normal method:
Save the output of the first result, and feed that back into another filter. The not so easy way: Copy the entire component structure of Filter A and paste it into Filter B. Connect where Filter B's image input with the end result of Filter A. Note that this only works if the filter is a 2D image filter and not a surface filter. The 3rd party way: Grab batchtool by Aba here: http://www.abalijon.nl/FilterForgeBatchTool.aspx The program lets you stack filters and make your life easier! Overall: FilterForge by default doesn't have filter-stacking sort of functionality. |
| Posted: June 29, 2014 10:55 am | ||
filteratha
Posts: 3 |
Thank you very much, Skybase.
I appreciate it. filteratha |
| Posted: July 6, 2014 12:38 am | ||
266 unregistered users.
