This is the filter : Cephalaspis The bomber has a problem : "The subtree of this Particle input includes size-independent components..... " etc etc. I know I used "Scale", "Offset", etc. , otherwise it wouldn't be possible to make the base for the particle. I tried to use a Particle Adaptor, as it suggests, but it doesn't solve the problem. What do you suggest to do? |
| Posted: June 23, 2014 10:53 am | ||
Debug. Work your way backwards until the error goes away. Look for XY anchors other than "default (size)" or size-independent components (image, selection, frame, or color/grayscale control with images allowed). There must be at least one.
Also, cool creatures! |
| Posted: June 23, 2014 7:30 pm | ||
Thanks Indigo Ray.
I hope I can solve. |
| Posted: June 25, 2014 12:51 am | ||
JoannaK
Hi, i really love these 'fishies', well designed and look really nice.
I'm too noob to be !00% sure, but I noticed that the 'Scales' group uses Frame component. As far as I know it's the culprit. I'd also upd ated the old components (like offset) on that group. These modifications may cause some image differences, apparently offse t components XY/HV values have changed between versions. |
| Posted: June 25, 2014 10:22 am | ||
| Posted: June 25, 2014 3:02 pm | ||
Joanna was probably right. Your "Scales" group has both old frame and old offset components. All of the bomber inputs had the warnings, so it looks like (argh) you will need to update your components to version 4, probably a group at a time until the problem goes away, like Indigo Ray said. BTW, very interesting code in scales
| Posted: June 25, 2014 6:31 pm | ||
Thanks JohannaK and Rick! I'll change them. Maybe that's the problem.
| Posted: June 26, 2014 8:43 am | ||
