I'm kind of having a hard time mapping a pattern onto a sphere. I thought a Circular Arc with a Tile- or Frame component (sphere) as height into a Refraction component would do the trick but it doesn't. The edges look fine but for some reason the middle (which should have hardly any offset) tends to shrink a little.
The attached filter will show you the problem. It is clearly visible in pattern nr 4, the egg looks dented instead of round.
Easter eggs.ffxml
Try this...
sphere.ffxml
Here's another method which works better for more complex objects...
texture mapping.ffxml
Ah great! smile:D
thanks
(you should submit those as snippets, the're very usefull)
22 unregistered users.
